![]() Join Date: Nov 2013
lowering the 71 stepside
2.5 dropped spindles,& 1" springs, front shocks, Rear 4" dropped springs, rear shocks, Shock relocate Kit. Is there anything else I will need ??
Re: lowering the 71 stepside
Looks like your good to go.
Scott |
Take a look in the rear and make sure your spring cups aren't rusted out. Nothing like getting ready to do a job just to find out you need more parts.
![]() Join Date: Feb 2013
An adjustable panhard bar would not be a bad addition.
I went with a track bar and have been quite happy with it. |
I have a 1971 shortbed stepside and lowered it 4 1/2 in the front and 5 in the back. I have a Porterbuilt adjustable trac bar and it's still sitting on the shelf. I think why I didn't have to use it was because I did 3 inch drop springs and 2 inch drop blocks in the rear.
Scott |
That is just about the same thing i'm doing. I have 2.5" drop front spindles with 1" frop springs and then was going originally with a 3" rear drop spring, but think ill go with a 4" drop spring. Not to steel the thread, but are rear shock relocates required for the 4" rear drop?
Can lowering blocks be used with rear coils ? Might be a dumb question. Thanks
67-72 parts collector,…
![]() Join Date: Nov 2002
yes
laying low
![]() Join Date: Mar 2001
Yes on the blocks but 2" is thought to be the limit due to scrub line.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
This is good advice. Just went through the same with my 67. I would recommend changing them even if they seem ok. Panhard bar was also mentioned which would be another option, although though not as important as the spring cups in my mind.
![]() Join Date: Aug 2008
Shorter shocks?
Called Summit today to find some lowering blocks, I installed some 4" lower springs but only dropped about 2.5 " Summit told me that they don't have any lowering blocks for trailing arms with coil springs. Do I make my own. Need help. Thanks
#13 |
#14 |
Whats a scrub Line ?
#15 |
http://www.steffysgarage.com/downloa...line-chart.pdf
Too large of lowering block will make the trailing arm drag the ground in the event you would have a flat on that side. (basically holding the wheel off of the ground) This would affect your ability to stop using that wheel's brakes. It also makes the trailing arm very close to the ground. I never use more than a 1.5" lowering bock with 15" wheel. On my trucks with 20" wheels, I use a 2" lowering block.
