Old 06-05-2015, 11:48 AM   #1
cstm68
cstm68's Avatar
Bothers 1 pice window help!
Iv had my brothers 1 pice windows in for a while now but I'm having trouble. When I roll the drivers window up it is really loose and lets it fall outward from the top channel. I can't find anyware in the instructions how to keep the bottom on the front track in place. It moves back and forth and Keeps the glass from staying lined up. Has anyone had this problem?
cstm68 is offline   Reply With Quote
Old 06-05-2015, 04:16 PM   #2
Mator
Mator's Avatar
Re: Bothers 1 pice window help!
It should have came with window tape which is like adhesive. It lays in the window regulator and secures the glass. I installed mine about a year ago.
Mator is offline   Reply With Quote
Old 06-05-2015, 04:26 PM   #3
Fldawg
Fldawg's Avatar
had the same probelm, i took the glass setting tape out and used urethane silicone,
course bottom line wish i would have kept my wing windows in
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 06-05-2015, 05:44 PM   #4
Lemield
Lemield's Avatar
Right there with you Fldawg! The one piece look nice but the OEM stuff just works better..JMHO.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 06-05-2015, 07:05 PM   #5
cstm68
cstm68's Avatar
It's not the channel that holds the glass, it's the front track that the glass slides in that attaches to the small aluminum triangle that bolts to the front corner. It's that part that was originally part of the wing window that the felt sits in
Old 06-05-2015, 08:56 PM   #6
Grumpy old man
Grumpy old man's Avatar
Reinvent the wheel and the wheel goes flat .it's like putting a Dodge v-10 in a vega there will be fitment issues .
Grumpy old man is offline   Reply With Quote
Old 06-05-2015, 10:06 PM   #7
mighty_mike015
The front channel is held in place by the triangle up top and and sheet metal screw down low. The screw comes in from the front side of the door. (the panel that the hinges are bolted to)
My guess is that either that screw has come loose or fell out all together.
mighty_mike015 is offline   Reply With Quote
