Square body mysteries
Let's talk square body mysteries , for instace why did gm place the Vin sticker on the door frame instead of the door jam ?
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
![]() Join Date: Jul 2014
Re: Square body mysteries
I've wondering the same thing. Was that just what they did back then or just a Gm thing?
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
With cars the vin had to be on the dash in 68 if i remember right,On trucks i have no idea when they had to but im sure no one changed tell they had to.
78K & 79C Jimmys
Sticker on the door I guess less chance getting damaged?
But then ,I've seen new vans etc the stickers on the jam, now. I figured it was to make the info easy to find like the rpo sticker.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#5 | |
If you are talking about the adhesive sticker on the door itself: it is of no consequence. No more than say a camper label (attached to the glove box) or a tuneup label (rad support) or a tire pressure label (door jamb) or even the SPID label (glove box). It could go anywhere but was placed there due to history and workload balance on the assembly line. If, however, you are talking about the VIN tag itself: it should be riveted (with rosette rivets) to the door opening ring near the striker, or to the dash panel depending on model year. That is a federal requirement for US built vehicles and is not negotiable. On the other hand, I have seen modern import vehicles (Honda, Toyota, Kia, etc) in our teardown displays at work that have VIN stickers (as opposed to metal tags), and/or are attached with push pins or plastic rivets. Unbelievable. We make such a fuss about it and yet I can swap VINs on those cutaway display vehicles with my bare hands. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-06-2015 at 11:15 AM. |
![]() Join Date: Oct 2014
As for the imports VIN stickers that are placed in the door jamb and other various places on the vehicle. These are actually very hard to remove once they are placed. And they also bleed into the paint.
The "riveted" vin plate is under the windshield. It is riveted to the body of the car. |
I meant that sticker on the door frame , I have seen quite a few that were missing or did not match the cab vin because the door was swapped .
Here is a Squarebody mystery that I have no explanation for. Maybe, Mr. Kieth Seymore can help. Over the years, I have seen several 81-87 Scottsdale trim trucks with the cab molding and several Silverado's that didn't have the cab molding. I even saw a 84 Custom Deluxe in the junk yard that had the molding and fender trim. Why did GM put the molding on the lower level trucks and not some Silverado's? On a side note, a friend and I did get the bed off the 84 in the pic. I went back about 2 weeks later to get the cab molding and fender trim, but the truck was sitting crushed on top of a pile of cars! What a shame, because the truck only had surface rust.
If the cab molding you are referring to is the one located just below the back glass, it's use may have been dependent on paint option. I only recall seeing it on models with roof color different from main body color. I think standard 2 tone paint had the roof the same as the main body color and deluxe 2 tone had the roof matching the 2nd color. I have seen some older model basic trucks with lighter color roofs only and they had that molding to cover the paint break. Chip.
#10 | |
Even had a white painted bumper, but for a while I worked at a Chevy dealer (same one where I bought it, a couple years later) and they had warranteed a chrome bumper for an itty bitty scratch. One of the managers let me snag it out of the scrap pile and I put it on my pickup ![]()
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#11 | |
The VIN tag locks down the vehicle identity. That's why it is permanently affixed to a structural part of the vehicle (door opening ring or IP dash panel). All of those other stickers are informational only. The only reason the VIN is on them is to make sure they get placed on the correct vehicle (they do not give the vehicle it's identity). That's why they can be stickers, and on components that can be swapped out (doors, rad supports, glove boxes, etc). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#12 | ||
Remember: back then your could mix and match as you saw fit. My own truck, a Scottsdale, should have had the single headlight grill and black side trim. However, I knew that I could add RPO V22 Uplevel grille and B85 chrome side trim and get a Silverado appearance package for less cost. K
#13 |
It was nice when you could order a vehicle and play with all the packages and get the vehicle you wanted, to fit your taste. Nowadays, when you buy a vehicle (especially Japanese imports), you buy a certain color vehicle and it's ONLY going to have 1 color interior. That's boring!!
The draw back from special ordering, was the wait time. But when it showed up, it was like Christmas morning, you had a vehicle that was built just for you. |
#14 |
My 85 is solid Frost White and has the cab molding. I have seen several other 1 solid color trucks with the molding. The blue and white truck doesn't have a paint line to hide, so why does it have the molding?
#15 |
At the body shop.
I want to see a 73 without drip rail and a white top.
I'd like to paint the roof white on my 73 and not sure where to break the color, or did they ever just paint the roof top and not the B pillar portion?
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-07-2015 at 09:00 PM. Reason: typo |
#16 | |
That trim got pretty scratched up from the top front corner of the bed hitting the cab when the frame twisted on jeep roads. Left a quarter moon scar in the trim.
#17 | |
I'd like to see the SPID(s) if you have them. We would be looking for something like a YG1 or YG3 exterior decor package. K
#18 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-08-2015 at 11:29 AM. |
#19 |
I never paid that much attention, but figured the under window cab trim came on upper trim trucks and only on base models with two-tone top. I never inspected the SPID, but have had three original solid color square bodies, '78 Silverado, '78 Scottsdale, and '84 Silverado, and they all had the trim. The last two were Camper Specials with the teepee, so maybe it comes with that option? The '78 Scottsdale had no side trim at all. It was a dually
#20 |
I think what Keith is saying is that the cab band is the option, it wasn't necessarily included with any particular group. In the "good ol days" it was possible to get just about any available equipment on any trim level. Silverado, Scottsdale, and custom deluxe only guarantee a particular fender badge. You could order a custom deluxe with four headlights power windows and carpet and a Silverado with vinyl floor mat, a 6cyl, and no power steering. Exaggeration obviously but you get the point. Now you can't do that. If you want a base model truck with carpet you have to get the interior comfort group that includes power windows, satellite radio, and power seats. The interior comfort group isn't available on base model trucks though you get bumped to the to the LT trim and have to get fender flares, 18" wheels, and tinted windows.
#21 | |
K
#22 |
Thanks, Keith. Here is the spid from my 85. Also, can you tell me what YH6 and ZQ2 mean?
#23 |
ZQ2 = power locks + power windows
YH6 is a sort of flexible "bonus package" RPO that could used for individual dealer packages, spring/summer sales or promotional colors, etc. It doesn't always have permanent content attached to it so it would be difficult to define at this point. K
#24 |
Why was the standard axle ratio for a "Trailering special" 3.08?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
#25 | |
