Old 09-04-2003, 12:47 AM   #1
bad 71 chevy
bad 71 chevy's Avatar
truck bed
This is goin to sound dumb but how hard is it to take the bed off of our trucks thanks
bad 71 chevy is offline   Reply With Quote
Old 09-04-2003, 12:51 AM   #2
1971 Cheyenne
1971 Cheyenne's Avatar
It's not hard at all, It' heavy though, have a good way to get it off. just unbolt it, unhook the wiring harness, and lift it off
i lifted mine off with me and two other guys. NOT RECCOMENDED!
Work smart, not hard
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 09-04-2003, 01:13 AM   #3
bad 71 chevy
are the bolts that hold it down the bolts that come up thru the bed or is it hooked up other places as well thanks
Old 09-04-2003, 01:18 AM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Yeah, the bolts that hold it on go down through the floor and the crossmembers. should be round heads on top and 9/16 on the nuts....if I remember right.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 09-04-2003, 01:25 AM   #5
bad 71 chevy
Thanks a lot i just have not have the time to get out in the dirt feld and check out what i got my self in to by selling it
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
Old 09-04-2003, 01:36 AM   #6
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
When I took mine apart, I found that the best tool for the job was my trusty flame wrench ( cutting torch). Since my 67 has seen its whole life here in the "salt belt", all of the bolts were pretty much bonded to the rails. And not to mention, the rails were pretty bad themselves. I just cut down the middle, had my 10 year old nephew hold up one bedside and I cut the bolts off. I had stands under them, he was just holding them upright. Then I unbolted the front bed panel and lifted the sides off. I figured that the cross rails were cheap enough, plus, what is it worth in time to try and save them? The whole job took less than 30 minutes.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 09-04-2003, 01:48 AM   #7
bad 71 chevy
mine is bet to crap but i sold it to a painter and body man for 200 that is half of what i paid for the dang truck so i am not complain i just never took one off befor and was kinda wandern thanks for the help
5 speed nv3500
3.73 rear end
Headmen headers
