06-06-2015, 03:12 PM | #1 |
Double wall to body seals
Any input as to how these are installed? My paint and body guy is having a difficult time. Got these from brothers so not sure if they are the correct ones.
06-06-2015, 03:24 PM | #2 |
Re: Double wall to body seals
Tagging along on this one. I will be replacing these soon on my double wall top too.
06-06-2015, 03:25 PM | #3 |
Full pic
06-07-2015, 09:30 PM | #4 |
Bump
06-08-2015, 11:28 AM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I know you said you have a double wall top but this may help.
Pic's of the weather stripping on my single wall. Bed rail seal. No fasteners are used. Just install with some weather strip caulk. This stuff. I've never had the opportunity to take a close look at a double wall top before. But the single wall has this channel around the window to hold the stripping. The weatherstripping in your pic look familier to the set I installed. The channel it sits in. Put back edge in first and use a screwdriver to set the front edge into the channel. Here is a close-up of how I fastened the bottom of the window seal. This is looking up from the bottom of the tops bed rail. Hope that helps. If not...just disregard.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-08-2015 at 11:35 AM. |
06-08-2015, 11:28 AM | #6 |
PM sent
06-08-2015, 11:30 AM | #7 |
06-09-2015, 11:37 AM | #8 |
Thanks for the input. Brother's had the part mislabeled. Just fyi. The part # for the top to window seal shows up in their system as a top to body seal which is totally different.
06-09-2015, 06:53 PM | #9 |
If you are talking about the seal around the window, it uses a T clip, i could only find round ones, just cut them off flat and it turns into a tee
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
