06-06-2015, 10:21 PM | #1 |
red or green
I have many panels that were primed about a year ago. now that the other pieces are all blocked and ready for primer, which will be best to scuff the parts that are primed already to receive an additional few coats of primer? red or green scuff pad? and why?
06-07-2015, 01:19 AM | #2 |
1961 crewcab
Re: red or green
when I was working at a body shop I was handed a red pad, unfortunately I did not ask why, but that is what I used on the painted parts to scuff...seemed like he told me it was the same as using 420(???) paper- I could be all wrong with the #'s
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-07-2015, 03:47 AM | #3 |
Re: red or green
yeah I always used red. problem is I have a bunch of brand new greens one, id hate to spend money for no real benefit!!!
06-07-2015, 11:11 AM | #4 |
Re: red or green
if you used apoxsee like PPG DP 90 you mite wont to use read if you used a softer primer green should work just do a a good job
06-08-2015, 07:28 PM | #5 |
Re: red or green
I have used both and depending on the primer I think either one will work and do a reasonable job. You must have that big box of green pads. I bought a box full and don't remember where they came from.
3M makes a gel that is called prep gel that you put on a scuff pad and it says it will "supercharge " the pad[their words not mine] |
