Old 06-06-2015, 10:47 PM   #1
apache200
apache200's Avatar
stepside bed install
As the title says im trying to install my stepside on my 58 and cant find any pics of the rear mounting points. My frame has two different holes at the rear and I cant remember which one the bed mounts to. Any help or pics would be greatly appreciated. Thanks Tony
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 06-06-2015, 11:23 PM   #2
billrobbobjo
billrobbobjo's Avatar
Re: stepside bed install
Do you have a Shortbox or a longbox? each are different being that if you take the inner chrome rails and match them inside the box it should line up the holes if u put the box close enough to the cab, which i think is like a 1 inch gap, I cut my long box into a short box, so i have been doing a bit of research, as well as comparing old parts to new ones.
1957 Short Box
http://67-72chevytrucks.com/vboard/s...d.php?t=671001
1969 GMC 3/4
billrobbobjo is offline   Reply With Quote
Old 06-06-2015, 11:41 PM   #3
apache200
apache200's Avatar
I have a shortbed. I have it mounted in the 2nd hole from the end of the frame now but i want to make sure its right as I want to start working on mini tubs for it
1955 BBW Fleetside
Old 06-07-2015, 04:07 PM   #4
_Ogre
_Ogre's Avatar
free mini tubs... cut out the bedside with a jig saw and weld in 3'' wide 10 ga
[IMG][/IMG]
shop air compressor timer
Old 06-07-2015, 05:57 PM   #5
57chevyman
57chevyman's Avatar
the way the rear sill lays on top of the frame in the back, theres only one set of holes that works. if you have the bed on the truck now, i cant see how you could use the wrong holes ? it mounts in the set of holes closest to the back of the frame
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 06-07-2015, 08:18 PM   #6
apache200
apache200's Avatar
Thanks 57Chevyman. Yes i have it sitting on there and it lined up with the rear holes and the ones right in front of them that you see in your pic. It had me wondering lol. Thanks for the pic! Its what i needed
1955 BBW Fleetside
Old 06-07-2015, 08:20 PM   #7
apache200
apache200's Avatar
[IMG][/IMG]
Thanks Ogre. I went to tractor supply and picked up a trailer fender to make the tubs with
1955 BBW Fleetside
