Old 06-07-2015, 12:03 PM   #1
gordyzx9r
Junior Member
gordyzx9r's Avatar
My what is it, do I need it, what's supposed to go there, how do I fix it post.
So, I'm trying to take care of a few minor things with my new old 1970 C10 I picked up recently.
I'm finding a few odd things here and there that I'm not sure either:
What is it?
What's it do?
Do I need it?
What was supposed to go in that mounting bracket (that nothing is mounted to anymore)?
I'd really like to gut anything and everything I can related to emissions controls. I don't live in an area where I need it...and most of it is dry rotted, capped off, and lines just sitting there anyways not connected to anything.
Is there a really good fuse box diagram somewhere? I downloaded the Chevrolet Chassis Manual from this site, but that's not exactly crystal clear.
The fuel gauge is not working. I need to troubleshoot that. What resources are there here to do that? There is a wire running from the center of the top of the tank (which I assume is the sending unit) directly to the fuse box. Is it supposed to be? Just to see what would happen, I pulled the plug out of the fuse box and the gauge went past full. I put it back in, and the gauge goes to empty.
gordyzx9r is offline   Reply With Quote
Old 06-07-2015, 12:03 PM   #2
gordyzx9r
Junior Member
gordyzx9r's Avatar
Re: My what is it, do I need it, what's supposed to go there, how do I fix it post.
More.
Old 06-07-2015, 12:06 PM   #3
gordyzx9r
Junior Member
gordyzx9r's Avatar
Even more.
Old 06-07-2015, 12:07 PM   #4
gordyzx9r
Junior Member
gordyzx9r's Avatar
And some more.
Old 06-07-2015, 12:16 PM   #5
cdowns
cdowns's Avatar
#9 rubber fuel line is a great way to burn it down to the ground
Old 06-07-2015, 12:38 PM   #6
67sss
67sss's Avatar
11 n 17 get rid of them, 14 blower motor power-hook it up. 8 fuel pump n tranny lines.3 valve covers, 4 flux capacitor-jk throw it away.
67sss is offline   Reply With Quote
Old 06-07-2015, 01:13 PM   #7
gordyzx9r
Junior Member
gordyzx9r's Avatar
Originally Posted by 67sss View Post
11 n 17 get rid of them...
Did you mean #7? Can I get rid of the canister by the battery and just put vent/filters from where those lines are coming from on the carb or motor?
Old 06-07-2015, 01:15 PM   #8
gordyzx9r
Junior Member
gordyzx9r's Avatar
They say fuel lines on them, but there is a place near me that makes custom braided lines.
Old 06-07-2015, 01:21 PM   #9
In The Ten Ring
Hardline isn't really that hard to bend yourself. Just an option.
In The Ten Ring is offline   Reply With Quote
Old 06-07-2015, 01:36 PM   #10
hugger6933
Ok a little too much in one thread for me to keep it all in my head till I got to the bottom , BUT, if you have no grounds place one from the head[where you have a bolt hole on the end] or intake or even the block to the frame them one from the motor to the cab. You can't have too many ground straps, it just helps the wiring out so much. The dist is not really out of place it is a HEI unit used on everything GM AFTER say 74. But they are so good and efficient that tons of folks retro place them on their trucks. The evap can what is it hurting there under the battery? If your trying to clean up it is pretty well hidden.
Good luck with the new truck and all of its "fun" surprises. Jim
hugger6933 is offline   Reply With Quote
Old 06-07-2015, 01:36 PM   #11
hugger6933
Oh the two wires twisted together are from the hot and the NSS to bypass it probably
Old 06-07-2015, 01:54 PM   #12
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
#6 is the vacuum port for an auto transmission. You did the correct thing to cap it since you have a stick.
#9 The distributor is not original to your truck as the HEI type did not come out until 75-76. It will work fine as it produced better, higher spark without using point and condenser. Just remember to gap your spark plugs to 45. The original ignition system with points the spark plug gap is .35
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 06-07-2015, 04:05 PM   #13
sKnNyPpY
sKnNyPpY's Avatar
Could #6 be a vacuum port for power brakes?
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 06-07-2015, 06:08 PM   #14
yuccales
yuccales's Avatar
Throttle linkage looks ok. You should have two "ball studs" that are screwed into the floor that the gas pedal snaps on to. Your braided ground strap could be slipped under a valve cover bolt. Good luck on your new project.
yuccales is offline   Reply With Quote
Old 06-07-2015, 07:54 PM   #15
D-rock1981
D-rock1981's Avatar
1 is auto resetting circuit breaker. I don't think it's factory.
D-rock1981 is offline   Reply With Quote
Old 06-07-2015, 08:19 PM   #16
Fitz
That's a long list of sins left by hackers in that truck! I would start with the fuel lines as what you have is really dangerous. You can get pre bent hard lines from many sources or just buy straight stock, a bender and a flaring tool and make your own. When you are finished you won't have to worry about burning your truck to the ground.
Fitz is offline   Reply With Quote
Old 06-07-2015, 09:03 PM   #17
MagmaJct
MagmaJct's Avatar
What is it?
What's it do?
Do I need it?
Putting aside the law not requiring it in your area, what's you reasoning?
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 06-07-2015, 09:20 PM   #18
burb71
Active Member
The ground strap attaches to the rear valve cover nut on pass side
burb71 is offline   Reply With Quote
Old 06-08-2015, 12:05 PM   #19
gordyzx9r
Junior Member
gordyzx9r's Avatar
Ah crap...they're not there.
Regards,
Mike
From what I've seen, most of it has been neglected to begin with and if I don't need it why worry about keeping up with it?
Old 06-08-2015, 01:06 PM   #20
MARKDTN
Canister purge is not evil. It is a passive system and would allow you to have a closed fuel system. That makes it so less fuel evaporates, less fuel smell, etc. I am a big proponent of converting to fuel injection and getting rid of as much as possible, but I always leave canister purge.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-08-2015, 03:03 PM   #21
Bigdav160
Bigdav160's Avatar
1. Circuit breaker - Not original equipment. Someone added one to mine like that when they installed a electric brake controller
2. Vacuum ports. Best guess is the carb is not OE and those may not be used in your application
3. Back of cylinder head or valve cover
4. No idea. Perhaps an old alarm module harness
5. Pink is your ignition power.
6. Vacuum port for the transmission modulator
7 Evaporative canister purge line
8. Evaporative vapor line from gas tank and mechanical fuel pump
9 As mentioned, big cap HEI and rubber fuel hoses on the pressure side.
10 I'm pretty certain that is not correct. The brown wire needs to go to the instrument cluster.
11. No idea.
12. Needs the floor mounted gas pedal.
13. Looks to be the resistance wire that use to go to the points distributor.
14 Blower motor and it's connector
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-08-2015, 03:49 PM   #22
57taskforce
All about them K’s
57taskforce's Avatar
Correct me if I'm wrong but If that hole in the bed for the aux filler is on the drivers front side of the bed its most likely a 71-72 bed if it's at the rear of the drivers bed side it's a 70. That's assuming that the hole is factory of course.
Tyler
57taskforce is offline   Reply With Quote
Old 06-08-2015, 08:42 PM   #23
Custom/Ten
Custom/Ten's Avatar
#13 is the brake warning lamp wire. Here's a pic.Name:  image.jpg
Size:  53.3 KB mine is about 4ft. Long so I ran it up into and back out of this temporary wiring loom I have set up for now. My wire changes colors because part of it was exposed, part of it was taped, and part of it was painted which has been flaking off over the years so it has faded differently in different areas.
Custom/Ten is offline   Reply With Quote
Old 06-09-2015, 10:05 AM   #24
gordyzx9r
Junior Member
gordyzx9r's Avatar
Hmm...this wire goes directly from the middle of the top of the tank, directly to the fuse box. If I'm reading the wire schematic right, that's how it is there too.
Old 06-09-2015, 10:06 AM   #25
gordyzx9r
Junior Member
gordyzx9r's Avatar
It's on the front drivers side. And the cargo box is on the passenger side. I'm thinking either aftermarket or a '72 bed.
