Rubber or Poly?
I'm replacing all the rubber bushings in my '72 GMC and am debating original rubber vs. polyurethane. I'm concerned about the noise and harshness of the poly but am curious about how much of a difference it would make to the overall handling. Anyone put poly in and regret it? People satisfied with rubber?
![]() Join Date: Sep 2014
Re: Rubber or Poly?
from everything that I read everyone recommended going with rubber for the mounts. That what I did and they work great.
Re: Rubber or Poly?
Years ago i put poly mounts on my daily driver threw them in the garbage about one and half months later then went back to original rubber
Re: Rubber or Poly?
Now they WILL affect the handle on the truck/car they are put on. But they squeak and make the ride rough[er]. I would recommend staying with a [quality] type rubber product.
#5 | |
Re: Rubber or Poly?
Re: Rubber or Poly?
I have used poly engine and transmission mounts but will never do so again they transmitt to much vibiration. The only place for poly on my trucks now is sway bar bushings.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: Rubber or Poly?
Thanks to all the replies. I'm going to go with rubber and then poly in the sway bars.
