06-07-2015, 06:08 PM | #1 |
Frame rivets and stuff for 71 Chevy Custom Deluxe?
Stage one cleaned the frame under the "missing" bed today, for the 71 Custom Deluxe. I hit it nearly 20 years ago with Krylon, and believe it or not, it's held up real well. A "couple" things have come up, including:
1. I found that one of the rivets for a leaf spring mount to frame is missing. I suspect it's been that way since new. I could just use a bolt, but nah, I'd like it to be right. Any recommendations? I don't have the equipment or knowledge. 2. I'm considering using POR15 Chasis black for the refinish. What's your opinion(s) on scuffing up what's there and applying it, as opposed to stripping this down to metal? 3. I'm thinking about removing the leaf springs for refinish. Seems to be straight forward. Support the axle, remove a bolt from each side of the leaf springs, remove the nut on top/center of the leaf springs (can't tell what type of bolt that is), and the four bolts from the hanger brackets. Am I missing something? 4. I need shocks. I'd like to stick to the original theme. Any suggestions? 5. I may want to replace the exhaust system. Again, I'd like to stick to the original theme. Any suggestions? "couple things". Thanks for any input.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-07-2015, 06:16 PM | #2 |
Re: Frame rivets and stuff for 71 Chevy Custom Deluxe?
Can't and won't speak to the rivet BUT on the newer trucks, the top rear rivet is missing on the rear hanger for a bolt to go through for the back bumper but I don't think this situation is the same, I haven't paid attention. I do know I have had to replace a spring hanger on a newer type frame and did bolt it on with a double nut then tacked the end nut to the bolt threads to keep it from backing off. Kinda like a rednecks nut lock. Be careful when unbolting the springs they are heavy and it might be best to clamp them together with a c-clamp to keep the springs close to together until YOUR ready for them to come apart. The bolt in the middle[called the tie bolt] is gonna be a booger to get off you may have to cut it, there is no bolt head on the bottom it is round to fit in the lining hole.
06-07-2015, 07:35 PM | #3 | |
Good idea, thanks for the info. Doesn't surprise me the tie bolt would be a bear.
06-08-2015, 07:41 AM | #4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-08-2015 at 11:34 AM. |
06-08-2015, 12:20 PM | #5 |
Thank you Keith
06-08-2015, 01:22 PM | #6 |
I can tell you that correctly installing a 3/8" steel rivet into that hole requires tools and experience...which very few people outside of the industry actually have. It isn't rocket-science, it is blacksmith-science. I've driven (and bucked) about a gazillion aluminum aircraft rivets and only hot-driven a few smaller steel ones.
It can be done...but sometimes a 'one rivet' journey is better to read about than to experience. "May the Bolt be with you..." ;-)
===Marc '55 Buick Roadmaster Riviera 76R '69 Chevy C-10 CST/10 396 LWB, auto, air, PS (PB soon!) |
06-08-2015, 06:25 PM | #7 | |
06-09-2015, 01:20 PM | #8 |
I'm going to borrow this on occasion, if you don't mind.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-09-2015, 01:44 PM | #9 |
Even the FSM advises reaming the hole to a very close fit for bolts in rivet holes. If the bolt isn't a light drive fit its just filling a hole.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-09-2015, 01:53 PM | #10 | |
My understanding is center bolts and U bolts should be replaced after disassembly too.
06-09-2015, 02:04 PM | #11 | |
http://www.waldronexhaust.com/ Thought Heartthrob had a big block 2wd kit for 68-72 but I can't seem to find it.... http://www.heartthrobexhaust.com/manifolddualkits.htm
06-10-2015, 12:19 AM | #12 | |
06-10-2015, 12:25 AM | #13 | |
