Old 06-07-2015, 07:54 PM   #1
tucsonjwt
BBC Crank Pulley in Steel like original - source?
The crank pulley fell off my 454 C20 for the second time. Two bolts worked loose and spun the crank off - cracked the pulley. I have tried an aluminum replacement when the first one broke, but the v belts would never stay tightened. I found a used OEM steel pulley, but now I need a second one.
Does anyone know of a source for a steel pulley?
Should loctite be used on these bolts? If so, what kind? Also, any recommendation on replacements bolts? ( I only have one left.)
Part number stamped on part is 3937787-AC. It is a 3 groove pulley - about 7 3/4" diamater and 2 3/4" bolt pattern.
Thanks.
tucsonjwt is offline   Reply With Quote
