Old 06-07-2015, 10:10 PM   #1
70chevytruck
radiator heater hose question
So my new radiator doesn't have an inlet for my 3/4" heater hose.
Other heater hose goes to intake manifold. Where can I run this heater hose to.....the water pump?
70chevytruck
70chevytruck is offline   Reply With Quote
Old 06-07-2015, 11:22 PM   #2
D-rock1981
D-rock1981's Avatar
Re: radiator heater hose question
Yup
D-rock1981 is offline   Reply With Quote
Old 06-07-2015, 11:28 PM   #3
FirstOwner69
FirstOwner69's Avatar
Run it to a nipple on the passenger side of the water pump if you want to duplicate the original setup on a 70 with a small block.
FirstOwner69 is offline   Reply With Quote
Old 06-08-2015, 12:46 PM   #4
SS Tim
SS Tim's Avatar
IIRC Automatic and A/C trucks returned to the radiator for better overall cooling and base trucks returned to the pump for quicker warmup. Going have to go look that up.
SS Tim is offline   Reply With Quote
Old 06-08-2015, 12:56 PM   #5
old Chevy guy
old Chevy guy's Avatar
That's where it goes on my 71. Water pump that is.
old Chevy guy is offline   Reply With Quote
Old 06-08-2015, 01:37 PM   #6
davepl
davepl's Avatar
I've only seen 6-bangers return to the radiator myself in the book. I know my '70 AC truck is the same as any other 1970 GM car, the lines run to the water pump and intake manifold.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-08-2015, 01:43 PM   #7
Jonlopes
My 71 396 with AC returns to the radiator. I don't suppose it matters too much.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-08-2015, 01:51 PM   #8
FirstOwner69
Actually, I think through 1970, at least on small blocks, the 5/8" hose went to the intake and 71s and 72s had one hose (not sure which one) to the radiator. That's based solely on my 69 with A/C and TH400, observations from this forum and some junkyard trucks. It may vary depending on which radiator size (number of cores/rows) is used. Mine is 4 row.
Old 06-08-2015, 07:41 PM   #9
SS Tim
SS Tim's Avatar
Like I said I still need to go look through some documentation. But here is a 72 fsm page showing the radiator return on TH350/400 trucks.
Originally Posted by 70chevytruck View Post
So my new radiator doesn't have an inlet for my 3/4" heater hose. Other heater hose goes to intake manifold. Where can I run this heater hose to.....the water pump?
Since the OP states his "new radiator" does not have the inlet for the heater core outlet hose it be safely assumed his old radiator did.
Old 06-08-2015, 07:44 PM   #10
davepl
davepl's Avatar
Given my factory Harrison rad doesn't have such a port, don't know what to tell you. Maybe it's because I have AC.
I still think it's a terribly slow way to warm up an engine, as it bypasses the thermostat. I don't get the design at all.
Old 06-11-2015, 12:28 PM   #11
MagmaJct
MagmaJct's Avatar
It makes sense if you think about it. The coolant leaving the heater core is passed over the ATF heat exchanger to pre-heat the ATF. Very little cooling occurs, as the coolant leaving the heater core is returned to the same side of the radiator that leaves the radiator. That is, the coolant leaving the heater core does not pass through the radiator core, so it receives very little cooling.
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
