What type of differential do i have?
i am trying to find out what type of differential i have in my truck. i have a 71' GMC C-2500. it is 3/4 ton full floating rear end. this is all i know. it is original and i want to change the rear gears so it is more streetable. the truck is 2wd. i was once told it is probably a dana 60 and someone else said it was a GM 12 bolt. i don't know anything about differentials and need help finding out what rear end i have before i try to order new gears.
thanks for any help! ronniej ![]() |
If it has a round cover on the back with a drop out differential assembly it's an Eaton HO72. If it has a non-round cover with a drain plug in the cover it is a Dana 60.
I think those are the only options for a 3/4 ton, but I don't know for sure.
Eric 1969 K20, 465/205 package |
user # 2756
![]() Join Date: Jun 2001
Does it look like my avatar pic? If so it's a dana60. If it has a round cover and drop out center section it's a corperate axle. More likely the dana 60.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Try this link. You can compare the pictures with what you have.
Jim http://www.coloradok5.com/axleguide.shtml |
looks like it is a dana 60. now, how do i find out what gears it has in it?
thanks for the info! ronniej ![]() |
Gotta Startem Early
drop the cover, count the teeth on both pinion and the ring and then divide the pinion into the ring. You could probably use new oil anyway.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
![]() Join Date: Feb 2000
usually if no one has messed with your diff before, there should be a tag on one of the lower cover bolts that says the ratio and the number of teeth on each gear. I've seen quite a few and have a couple so they may be a good chance yours is still on there.
Never saw a tag on one, except on F&%d 8 inch and 9 inch. I have one with a 14 bolt cover. Was told the only gears available are 390, 411 and 456. Was further told to find one from 73 up with 8 lugs and it can be modified to work with my leaf spring Longhorn.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
