Old 06-08-2015, 12:27 PM   #1
Bigstevex4
Bigstevex4's Avatar
Moter mount position
Ime pretty sure I know but. I pulled the 6 out cleaned up Eng. bay set v8 in had trouble stabbing the 4 speed but went to set motor mounts are in to close
And huge expletive!!! Now I see another set holes. the picture is looking strait down you can see the 2 holes above the mount exhaust manifold on top. just wanted to make sure that all it is needed to do.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 06-08-2015, 01:48 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Moter mount position
The two sets are stamped/labeled "6" and "8" on the engine mount stands...put the engine mounts for the V8's in the "8" hole and inlines in the "6" hole. Just move the engine mounts on the stand, and you will be good to go.
bigblock73 is offline   Reply With Quote
Old 06-08-2015, 04:31 PM   #3
Bigstevex4
Bigstevex4's Avatar
Thanks didn't see it before set eng in getting old blind. when I started in shop at 19 those old guys back then always had a trouble light in there hand ime like get that out my eyes now I get it at 57
90 Jimmy parked
In memorium
Old 06-08-2015, 06:35 PM   #4
greg64
greg64's Avatar
Steve, I changed the mounts on my six years ago, so I knew about the two sets of bolt holes. As I remember, holding the nuts on the back was a bit of a challenge.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-09-2015, 02:01 PM   #5
Bigstevex4
Bigstevex4's Avatar
looks to me like pulling the mount brackets then move the mounts out with the brackets on the benchthen reinstall brackets is the way to go I think?
90 Jimmy parked
In memorium
Old 06-09-2015, 03:25 PM   #6
bigblock73
yeller
bigblock73's Avatar
The bottom bolts on the plates, that go to the crossmember...are also a PITA to get to. Half a dozen of one, 6 of the other...either way, it kind of sucks.
Old 06-09-2015, 04:26 PM   #7
mrolds88
Interesting. I swapped a 350 into my fathers truck (80 k10) that had a 250 in it from the factory. Dropped right in and everything lined up.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
