Old 06-08-2015, 01:27 PM   #1
sags
65 SWB suspension question - a little too low
Looking for a little help and suggestions on this. Swapped out the front drums in my 65 for disc brake package this weekend complete with new master and power booster. Brakes work great. I almost put myself through the windshield the first couple times. I went with 2.5 inch drop spindles and once I got everything back together, I realize that the previous owner must have cut more off the springs than I thought. It is a little too low (although I like the raked look). Only about an inch above the bump stop and it bottoms out easily and harshly. So here is the question. Replacing the front springs with taller springs should fix this right? And if I went with, say a 1" lowering spring, would that still be higher? I need to get the fenders up a little relative to the tires. Also, I suspect that the rear springs were also cut so if I go with a 3" drop spring, should it level things out a bit?
sags is offline   Reply With Quote
