06-08-2015, 05:32 PM | #1 |
Moderator
Trans Mount Question
What kind of trans mount is this? And will it work for a automatic trans behind a 350ci with a low hump cab?:
06-08-2015, 06:04 PM | #2 |
Re: Trans Mount Question
It looks like a 70's or 80's transmission cross member.
06-08-2015, 07:49 PM | #3 |
Moderator
Thanks Classic.
Anyone ever use one for the installation I talked about above?
06-08-2015, 08:11 PM | #4 |
I have not seen anyone use one on our year trucks but it could probably be made to work.
06-08-2015, 08:19 PM | #5 |
06-08-2015, 09:45 PM | #6 | |
Moderator
Do you think thats a low hump or high hump being used with the 700R4?:
06-08-2015, 09:52 PM | #7 |
you can use a low hump but you have to massage that lip under the floorboards under the firewall
ron |
06-09-2015, 01:33 AM | #8 |
60-66 Nut
GM started using that style of trans crossmember around '79. The style of trans crossmemner is not dependent on whether a low hump or tall hump is used. The low hump will work with most automatics, but sometimes the lip at the front needs to be massaged as Ron mentioned.
That trans mount shown in the pic looks awfully tall.
06-09-2015, 06:07 AM | #9 |
Moderator
Lip Aye.
Thank you Cap'n Yes they both look tall, that's why I was wondering if it'd work.
