Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-08-2015, 05:59 PM   #1
greywuuf
68 C60 will a 6v53 fit
I have seen a number of 4-53's stuffed in almost everything including 50-60 series trucks, but I have never seen a 6-53. I assume they are shorter and would therefore fit but has anyone ever done it ?
greywuuf is offline   Reply With Quote
Old 06-08-2015, 06:33 PM   #2
Deerelindel
Re: 68 C60 will a 6v53 fit
I put one in a 68 3/4 ton and it fit but the thing is really heavy, and good look finding parts.
1968 GMC 1 ton 4*4 with Detroit Diesel 6v53t 9ft stepside
1978 Chevrolet C50 350sb 8ft fleetside
Deerelindel is offline   Reply With Quote
Old 06-08-2015, 06:41 PM   #3
greywuuf
Thanks....
for the most part x-53 parts are 53 parts, should not be any harder than parts for a 4-53.. or am I missing something ?
Old 06-08-2015, 07:31 PM   #4
Deerelindel
Originally Posted by greywuuf View Post
Thanks....
Not really but the 4 is inline and the 6 is a V but i know rocker covers should fit between the 2
Old 06-08-2015, 07:45 PM   #5
C10 - C90 Bill
C10 - C90 Bill's Avatar
Sounds like an interesting truck.
Do you have any videos of it ?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 06-08-2015, 07:57 PM   #6
Deerelindel
I do somewhere but here is my photobucket album of the build.
CLICK HERE
Old 06-18-2015, 12:18 PM   #7
84rzv500r
8V-71 fits
72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138
71 Corvette Wide Body 502 Ramjet
83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R
05 MB E55 AMG, 12 45th Camaro SS stick vert
84rzv500r is offline   Reply With Quote
Old 06-18-2015, 01:47 PM   #8
greywuuf
^^^^tht is MY kind of thinking right there!
Old 06-18-2015, 05:26 PM   #9
C10 - C90 Bill
I'm really surprised on how much "forward" you got the Shifter to be located at.
Is it a Road Ranger Trans ?
GMC 9500 Fan
Detroit Diesel Fan
Old 06-18-2015, 05:47 PM   #10
84rzv500r
yes RTO-9513... I used the stock front motor-mount location and the rest was dictated...
I will shorten the shifter a bit... in truth the driveline components drove everything else. the intermediate shaft is as short as it can be and still allow it to be removed for service.. and that BIG Rockwell T-1138 Overdrive Transfer case prevented me from sectioning the frame and just using an 8 foot box... as there would be no hope of serviceable drive line angles. as it is the front driveshaft is a LONG whippersnapper and weighs almost 100 Lbs...
I have all the square tube and sheet metal for the doghouse and two other trucks for body parts... I just haven't had time to work on it much...
Old 06-18-2015, 05:52 PM   #11
greywuuf
I PM'd you about your running ear, but since you have covered most all of it here... what front axle is that? I do not believe I have ever seen a driven Dayton front before.
Old 06-18-2015, 07:07 PM   #12
84rzv500r
its a napco 2.5 ton... it has adapters form rockwell pattern to dayton... pretty common back in the day...
