Old 06-08-2015, 10:50 PM   #1
chevykevy
chevykevy's Avatar
Do you think I can fit a stock Fan shroud?
Hi all,
I have a 64 with a 71 front crossmember and the 71 engine perches. The engine is in the forward set of holes on the frame rails. I want to use a stock 66 shroud if I can. The measurement between the stub of the short water pump and the radiator is 5 inches. think it will fit?
chevykevy is offline   Reply With Quote
Old 06-08-2015, 10:53 PM   #2
chevykevy
chevykevy's Avatar
Re: Do you think I can fit a stock Fan shroud?
How deep is a stock shroud from where it meets the face of the radiator to its most narrow part of the opening closest to the engine?
Old 06-09-2015, 12:36 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
If you need some measurements I can measure mine for you.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-09-2015, 02:04 AM   #4
Captainfab
60-66 Nut
A stock shroud measures 6-7/8". The fan will be too far into the shroud to properly move air and I don't know of there is enough depth of the lip to trim it back and have it work properly. It will somewhat depend on the fan you use. This is one of the things I warn people about when they want to move their engine forward.
Old 06-09-2015, 08:06 AM   #5
chevykevy
chevykevy's Avatar
thanks guys. Any idesa for a different shroud that may fit?
Old 01-24-2017, 03:56 PM   #6
CVANN
CVANN's Avatar
I looking to do the same thing. Out junk yard has tons of shrouds down there. Anyone know of a shroud I could make work?
CVANN is offline   Reply With Quote
Old 01-25-2017, 02:13 PM   #7
Brad54
Brad54's Avatar
What's the benefit of moving an engine forward? I can see it if you're installing a big block, because you don't really have any choice. But they came with a small block, and it was installed in a spot that uses factory components--like a fan shroud.
Not only that, but moving the engine forward hurts handling. It's not like these things handle great to begin with, but moving the engine forward just makes it worse.
So what's the thinking with moving it forward?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 01-26-2017, 12:36 AM   #8
Captainfab
60-66 Nut
I think most that do it, do so because they think that the HEI distributor is too close to the firewall. I have never had a issue with that and typically say so when someone asks about it. Some even compound the moving the engine forward issues by going with a long water pump too.
-Brad
Old 01-26-2017, 06:09 AM   #9
corvettejim1968
corvettejim1968's Avatar
my stock shroud is in front of the radiator. i went with the electric fan.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 01-26-2017, 12:06 PM   #10
Brad54
Brad54's Avatar
Weird. I've got an HEI on my '62 Suburban, and there's no problem with clearance at all.
-Brad
Old 01-26-2017, 12:18 PM   #11
343CA
I know a mid 60's Impala fan shroud is used a lot during swaps. Check the opening and clearance of fan space like Captain Fab mentioned.
343CA is offline   Reply With Quote
Old 01-27-2017, 01:14 AM   #12
Captainfab
60-66 Nut
I have never had an issue either, but some think it is just too close.
-Brad
