Old 06-09-2015, 02:13 PM   #1
Domer
Domer's Avatar
Project Roxy
So i have finally decided to post a build thread. My project is a 77 C10. I got it bagged and body dropped from a good friend of mine. It had a full custom chassis under it, and it would cruise and steer 1/2" off the ground. I rolled it for awhile.
Here is what it started as when i got it.
The problem was it was underpowered and the engine leaked like a siv, and the trans was slipping. so i pulled it a part and started working. I built a 355 for it with a forged crank, H-beams rods, and dish pistons, with a set of World Sportsmen 2 heads with a 76cc chamber. giving me a ratio of 8:1. Next came a 6-71 blower. Fed with a set of gold plated edelbrocks. ( this project was put together with wheeling and dealing). and a big blower cam. Had the TH350 built to handle the engine. Had a 2500 stall converter, and I already had an Impala rear axle, still with the 3.08 gears.
Here is version 2 of the truck.
I drove it for awhile and abused it pretty good. The problem with it was that the truck was cool to drive, but it wasn't fun to drive. it was alot of work and it didn't handle worth a damn. So on to phase 3 of the project. I ended up parting out most of the truck to friends, and i got a rolling chassis and nice body to start over with. The frame i had wouldn't have been condusive to try and modify to what i wanted to do. So after researching and reading everything i could find on making a c10 handle i went to work. As I am typing this I am at work and don't have alot of my progress pictures and will upload more later on at home.
I went to work on the crossmember, and notched it 3" to raise it up around the frame. I sectioned part of it to clear for a Rack and pinion from an 88 Tbird. I used Mcgaughy's drop spindles with 13" disc brake kit and 2 piston calipers. The control arms i ended up using were a set of DJM Drop arms that i got for $100. The coils are an unknown amount of drop. I did the caster mod with the lower control arms and pushed the lowers forward 3/4" and drilled out the pins and replaced them with 7/16-20 allen cap bolts in grade B16 for strength with a set of toplock nuts. Giving me a total of about 10" drop in the front.
I bought a Longacre caster/camber gauge and have been setting up all the front geometry, and have been working on my Instant centers and roll centers, and am getting it close to were it shouldn't handle like an old truck anymore.
Transmission was replaced with a T56 from a 95 Camaro, and clutch and billet flywheel are from local place here in san diego. The rear end right now has flip kit, 3 leafs removed, and a drop shackle. This is what came on the truck when i got it, and i have not gotten that far i mods yet.
So here is a teaser picture for right now and will upload more soon.
Domer is offline   Reply With Quote
Old 06-09-2015, 02:16 PM   #2
Domer
Domer's Avatar
Re: Project Roxy
So not sure why the last picture isnt working... will try and redo it tonight.
Old 06-09-2015, 04:57 PM   #3
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Project Roxy
looks like a beast with the blower just chilling there
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 06-09-2015, 05:27 PM   #4
tinydb84
tinydb84's Avatar
Re: Project Roxy
Mean looking truck!
David
Instagram: myfabguy
Old 06-09-2015, 05:39 PM   #5
rusty76
rusty76's Avatar
Re: Project Roxy
Pretty cool dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-09-2015, 09:17 PM   #6
Domer
Domer's Avatar
Re: Project Roxy
Caster mod completed.
Caster/Camber gauge to get everything set.
Bumpsteer adjusters that i built.
Boost distro block for the back of the head that feeds the carburetors and gauges.
Old 06-09-2015, 09:27 PM   #7
CDNchevydude
CDNchevydude's Avatar
Re: Project Roxy
Cool truck and great ideas! I'm in!
87 R-10 SWB
CDNchevydude is offline   Reply With Quote
Old 06-09-2015, 10:01 PM   #8
Domer
Domer's Avatar
Re: Project Roxy
Here is the cradles for the LCA with the 7/16 bolts installed.
And the LCA shafts that were milled so both bolts positively lock. the originals were over 1/2" off.
The 13" disk kit with spindles.
Custom billet flywheel for 2 piece SBC to LT1 T56 built by southland clutch here in San Diego.
3" notched crossmember
with rack and pinion installed
Studs i built to attach R/P
Boost block installed
http://s5.postimg.org/efr52ab6f/IMAG1589.jpg
Ride height right now
Old 06-09-2015, 10:27 PM   #9
Domer
Domer's Avatar
Re: Project Roxy
One thing i had a big issue with on the last build was header issues.. so i wanted to be able to clear a set of full long tubes in 1 3/4". Challenge accepted
Old 06-09-2015, 10:30 PM   #10
Domer
Domer's Avatar
Re: Project Roxy
Another big change was i wanted to get rid of the edelbrocks. They worked, but i maxed them out. so i replaced with a set of Holley 750 Double Pumpers that are boost referenced. And powder coated red/black. I will be re painting the truck the red and black.
Old 06-10-2015, 02:36 AM   #11
2000Limited
2000Limited's Avatar
Re: Project Roxy
Im in
2014 Dodge Charger SXT 100th Anniversary Edition
2009 Chevy Silverado Z71
1978 Chevy Scottsdale 4x4-Project "Colonel"- Build
http://67-72chevytrucks.com/vboard/s...d.php?t=632039
2000Limited is offline   Reply With Quote
Old 06-10-2015, 02:50 PM   #12
tinydb84
tinydb84's Avatar
Re: Project Roxy
How much ground clearance do you have? Are you going with a static drop? How much lower in your engine and do you have issues with the oil pan?
David
Instagram: myfabguy
Old 06-10-2015, 03:15 PM   #13
Domer
Domer's Avatar
Re: Project Roxy
I have 3" under the crossmember, its all static, but its not a daily. just a toy. The last version was bagged and i drove it about 1/2" pretty much everywhere. So height isn't an issue for me. The height was actually a by product of setting up the suspension how i wanted it. As for the engine i have about 6" of clearence as the engine is raised up to clear the steering rack and the long tube headers. i couldnt set it back any farther without it causing clearence issues with the distributor.
Old 06-17-2015, 10:05 PM   #14
Domer
Domer's Avatar
Re: Project Roxy
got my 305/30-20 mocked up. Gonna run them all the way around on a set of 20x10's.
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Old 08-02-2015, 11:09 PM   #15
Domer
Domer's Avatar
Re: Project Roxy
Here are some updates, got all the wheels in. 20x10 Jeep SRT8 wheels with 305/30-20 tires on all 4 corners. The jeep wheels are 5x5 but our spindle and nut are too long for the wheel, so I am running 1" spacers in the front, and because of the offset (+50mm) i am running 1.25" spacers in the rear.
Project Roxy...
Old 08-02-2015, 11:14 PM   #16
Domer
Domer's Avatar
Project Roxy Updated..
I have also been making quite a bit progress on my cage. Been a hell of battle between cage and keeping some street comforts. I managed to keep my bench seat, and running a 5 point harness. It will be complete from engine compartment back to the bed. Doing my best to make this thing as rigid and safe as possible.
Project Roxy...
Old 08-02-2015, 11:50 PM   #17
tinydb84
tinydb84's Avatar
Re: Project Roxy
Nice cage. Those rims look great on there as well.
David
Instagram: myfabguy
Old 08-02-2015, 11:57 PM   #18
Domer
Domer's Avatar
Re: Project Roxy
thanks.
Project Roxy...
Old 08-02-2015, 11:59 PM   #19
tinydb84
tinydb84's Avatar
Re: Project Roxy
If you didnt have the hub issue in the front would you need to run spacers? Is there a clearance issue else where? I wouldnt mind having some run that tucked in well.
David
Instagram: myfabguy
Old 08-03-2015, 12:02 AM   #20
Domer
Domer's Avatar
Re: Project Roxy
I dont think i would have any clearence issues. it would be tight around the shock area. I havent mounted my sway bar yet.. so not sure on that.
Project Roxy...
Old 08-03-2015, 12:05 AM   #21
Domer
Domer's Avatar
Re: Project Roxy
I think my biggest clearence problem that i solved, was doing my caster mod and moving my LCA forward 3/4". otherwise i would hit my control arm i think.
Project Roxy...
Old 08-04-2015, 06:38 PM   #22
Domer
Domer's Avatar
Re: Project Roxy
Tinydb84 - I was thinking, they make these wheels in an 8.5 or 9 also.. So you could stagger them to.
Project Roxy...
Old 08-04-2015, 11:49 PM   #23
c-man405
Re: Project Roxy
Hey man, sweet truck I like it a lot! Sorry if you said this already and I missed it but are those factory jeep wheels? Or did you buy replicas from somewhere? Also how did you move the lower control are out 3/4 of a inch?
Carter
c-man405 is offline   Reply With Quote
Old 08-05-2015, 12:40 AM   #24
Domer
Domer's Avatar
Re: Project Roxy
They are replicas of factory jeep grand Cherokee Srt8 wheels. As for the lca, look up caster mod. It consists of re drilling the lca shaft.
Old 08-05-2015, 12:54 AM   #25
tinydb84
tinydb84's Avatar
Re: Project Roxy
Thanks for the info. They are nice looking rims.
David
Instagram: myfabguy
