Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-09-2015, 05:45 PM   #1
Horacio
Horacio's Avatar
New shoes
Got some new shoes on today.
Horacio is offline   Reply With Quote
Old 06-09-2015, 06:38 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: New shoes
Nice! Looks great. I SOOOO need to get my panel on the road!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-09-2015, 10:25 PM   #3
Nobby
Nobby's Avatar
Re: New shoes
Looks Great Man!!I got to get a panel one day....
Nobby is offline   Reply With Quote
Old 06-10-2015, 08:06 PM   #4
Southcity
Southcity's Avatar
Re: New shoes
Looks great!- more pics and info on your wheel/tire setup please
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-13-2015, 12:19 AM   #5
Horacio
Horacio's Avatar
Re: New shoes
Tires are 225/60/18, not too low profile, I didn't want too much of a rough ride, these have enough rubber and ride nice.
The wheels are Mobsteel. 18x8 with a 4.5 backspace. I almost went with the 20", but I was concerned with clearance but I think they would have fit well. Ill run these for now, I like how it handles and drives and the stance isn't too crazy either way.
Old 06-13-2015, 09:44 AM   #6
Southcity
Southcity's Avatar
Re: New shoes
I'd say you nailed it with the complete package, paint scheme, stance and wheel tire setup, your panel really stands out - great job!
Old 07-11-2015, 02:57 PM   #7
Leon Rice
Re: New shoes
Looks Great! I'm getting ready to make a order from Mob Steel for my 66 GMC Panel. I'm wanting to go with the 20's. Question: Have you lowered your Panel, if so how many inches in the front and back?
I'm dropping my 4 inches all the way around and want to make sure I will have enough clearance with those rims with a tire package of 255/45/R20.
Any insight would be appreciated.
Leon Rice is offline   Reply With Quote
Old 07-13-2015, 11:32 PM   #8
Horacio
Horacio's Avatar
Re: New shoes
Leon I dropped it 5 in the rear and 3 up front. I was considering 20's but thought I might rub, but I think they will fit just fine. Your going with a pretty low profile tire so that will help too. I didn't want too rough of a ride and it doesn't, drives better than some newer vehicles I have and handles great. I did the drop spindle and shorter spring route by the way, not just cut or shorter springs
Old 07-14-2015, 05:46 AM   #9
Leon Rice
Re: New shoes
Thanks for the reply and suggestions. I am also going the drop Spring and Spindle route from CPP. The drop spindle they offer is supposed to pull the front wheels in on both sides 3/4 for a inch to help ensure no rubbing when running larger wheels and or tires. Just curious, what is the measurement (Clearance) from the ground to the front lip of wheel well? 29 inches?
Old 07-15-2015, 11:26 AM   #10
Horacio
Horacio's Avatar
Re: New shoes
With my wheel tire setup the front is sitting at just a shy over 28" and the rear at 24. Springs are fairly new, so I'm guess over time they might sag a little bit?
Old 07-17-2015, 10:19 PM   #11
duallyjams
duallyjams's Avatar
Re: New shoes
do you have any close up pics of the wheels
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-21-2015, 08:51 PM   #12
Horacio
Horacio's Avatar
Re: New shoes
Here you go
Old 07-21-2015, 08:53 PM   #13
Horacio
Horacio's Avatar
Re: New shoes
And another
Old 07-23-2015, 05:16 PM   #14
duallyjams
duallyjams's Avatar
Re: New shoes
Thanks for the pics.
James
IG duallyjams
Old 09-14-2015, 09:29 PM   #15
Leon Rice
Re: New shoes
Quick question, you used CPP parts right? I used their 2 inch drop Spindle and 2 inch drop springs and barely got a 1 1/2 total drop. Trying to figure out if there was some sort of problem with the parts they sent me.
Old 09-15-2015, 07:05 PM   #16
KIC
1960 GMC Burb
KIC's Avatar
Re: New shoes
Beautiful ride ! Great job !!
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 09-15-2015, 07:49 PM   #17
DPowers
DPowers's Avatar
Re: New shoes
Sharp
DPowers is offline   Reply With Quote
Old 09-16-2015, 07:38 PM   #18
Horacio
Horacio's Avatar
Re: New shoes
Yes Leon I used CPP parts, you changed out your shocks too? Not sure what the problem may be, you may have gotten the wrong parts, I did get a wrong bearing and two different size brake lines when I ordered.
Old 09-28-2015, 05:10 PM   #19
Leon Rice
Re: New shoes
Yes, I did put new shocks on it too.
