06-09-2015, 06:18 PM | #1 |
Carb problems
I have a 1972 C20 402 big block. I installed a rebuild carb of the same type. Quadrajet. Now my issue is that I can not get the truck off the line. When I try to give it throttle from a stop it hesitates and pops through the carb. Once the truck is rolling at approximate 10 MPH it seems to drive fine. Then it starts over when I have to stop at a light. The timing is at 8 degrees. new HEI dizzy.
Ideas? |
06-09-2015, 06:22 PM | #2 |
Re: Carb problems
All the lines hooked up? Vacuum?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
06-09-2015, 06:29 PM | #3 |
Re: Carb problems
Bump your timing up to 14 initial. Plug the vac line to the dizzy vac pot when you set it.
06-09-2015, 07:06 PM | #4 |
Re: Carb problems
06-09-2015, 07:06 PM | #5 |
Re: Carb problems
06-10-2015, 11:07 AM | #6 |
Re: Carb problems
Thank you geezer#99, that did the trick. the truck is running great now.
Thank you again. |
