Old 06-09-2015, 08:26 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
86 K5 component id game
I believe I know what they all are, but let's see what we have. 3 pictures, 3 items circled per picture. As far as I know everything is where it would be on a stock K5 but a PO put in a 350 w/ Holley.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-10-2015, 07:23 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: 86 K5 component id
No one wants to try?
Old 06-10-2015, 11:08 AM   #3
62 Longbed
62 Longbed's Avatar
Its funny that you posted this ... I have the same questions since previous owner changed carbs and threw away and discarded a lot of lines and connections on my 1984 ... Wanna find out as well ..
62 Longbed is offline   Reply With Quote
Old 06-10-2015, 11:34 AM   #4
esbstuff
I'll try...
1) Transmission shift thingly
2) Electric Distributor plug
3) Smog Solenoid Plug
4) A/C Pump wiring
5) Another smog thing
6) Dual Tank wiring
7) Cruise Control
8) No idea
9) Cruise Control
This should help...
esbstuff is offline   Reply With Quote
Old 06-10-2015, 08:34 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I think 1 and 3 are for the distributor and q-jet. 7, 8 and 9 for cruise control. 5 is the lock-up for the torque converter. Not sure about 2 and 4 or what 6 (2 wire plug) is.
Old 06-11-2015, 08:49 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Nobody?
Old 06-11-2015, 10:47 PM   #7
bdiamond
I believe #2 is for the converter lockup and #4 is A/C wiring. I think #6 may be backup lights?
bdiamond is offline   Reply With Quote
Old 06-11-2015, 10:51 PM   #8
bdiamond
Is that a clutch master cylinder and reservoir bracket I see in the last picture? If so then I don't guess you'd have converter lockup connectors....
Old 06-12-2015, 05:50 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It is, I just converted her to a 4spd. I have not purged the wiring yet.
Old 06-13-2015, 02:54 AM   #10
beamn7
I'll play..
#1= EGR solenoid plug
#2= Spark advance switch
#3= EST (electronic spark timing) connector
#4= underhood lamp option?
#5= TCC (torque converter clutch) vacuum switch
#6= pressure differential switch connector for combo valve?
#7&9= vacuum hose that feeds vacuum reservoir that is mounted on drivers side inner fender or cruise control
#8= TCC test port
Odd that it has a TCC vac switch cuz I see a clutch master cylinder. Was the manual swapped in?
beamn7 is offline   Reply With Quote
Old 06-13-2015, 09:13 PM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Originally Posted by beamn7 View Post
I'll play..
#8= TCC test port
Yep, I swapped in an SM465/NP205 combo. I need to clean up the wiring now. Is #6 for dual tanks?
Old 06-13-2015, 09:15 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Looks like all but 4 and maybe 6 can go.
Old 06-14-2015, 10:22 AM   #13
silverbear
silverbear's Avatar
I agree the #4 is for the Ac compressor.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 06-14-2015, 01:57 PM   #14
beamn7
K5's were a single tank only so I don't think that's what it's for....
Checked mine, #4 is A/C comp as silverbear said and #7 is cruise
Old 06-14-2015, 10:18 PM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks. I will trace out #6 and see where it goes.
