Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-09-2015, 09:50 PM   #1
tiddlar
wavetrac truetrac s trac ?
i bought the moser m 9 housing. Heard wavetrac is better than truetrac, and has lifetime warranty but people are breaking them. Midwest chassis, has a car running 9's on slicks and runs an s trac, has had it 4 years without a glitch. Can my moser housing accept the s trac? If not im stuck with wavetrac.... anyone have experiences with any of these? The truck is 89% street and the rest strip. I might put slicks on for the track. ill have mt s/r for street, t56 tranny, 1000 hp sbc twin turbo. Heavy 53 chevy truck. I dont think I will put it through too much abuse, but i would rather save myself the headaches. Thank you in advance gentlmen.
tiddlar is offline   Reply With Quote
Old 06-10-2015, 03:21 AM   #2
BigDan3131
BigDan3131's Avatar
Re: wavetrac truetrac s trac ?
Why aren't you just using the tried and true Detroit Locker? As long as its a 9" part any diff can be installed as long as the spline count is the same.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 06-10-2015, 08:58 AM   #3
tiddlar
I've been googling and googling and from what I understood the Detroit locker will be "clunking" around turns and waveyrac and strac are better for street/strip
Old 06-11-2015, 11:07 PM   #4
BigDan3131
BigDan3131's Avatar
If your making 1000hp and your exhaust is noisy there is no way you can hear it and its not a clunk clunk noise, its more of a click click click noise since its disengaging the gears as you turn the corner. Since were in trucks and the cab will be insulated I doubt you will hear it over the exhaust. Better to have a little noise then to start breaking stuff isn't it?
Old 06-11-2015, 11:20 PM   #5
C10Greg
I have a moser M9 fabricated housing. I am running moser 35 spline axles with a Strange S Trac and Strange HD Pro Aluminum Case. Can't tell you anything else about it yet because it is at the rear end shop getting built.
C10Greg is offline   Reply With Quote
Old 06-11-2015, 11:32 PM   #6
tiddlar
O man, that's what I am leaning towards. Midwest chassis has a car running 9's on slicks with s trac 0 problems. They as well suggested the pro hd aluminum. I already have the moser m9 housing with 35 spline axles. I guess we will test it out together.
Old 06-11-2015, 11:33 PM   #7
tiddlar
You do make a valid point ...
Old 06-11-2015, 11:33 PM   #8
tiddlar
Where did you purchase your center section and how much?
Old 06-11-2015, 11:54 PM   #9
C10Greg
I bought everything from Summit and I purchased it all individually. I think the HD Pro Aluminum Case was $785, the S Trac was $995 and the REM and EDM polished 3:89 Motive gears from C&R Racing but I don't remember what I paid for them.
Old 06-12-2015, 12:02 AM   #10
tiddlar
I'll check it out, appreciate the info
