Old 06-09-2015, 10:38 PM   #1
Cautrell05
Frame mounted M/C with S-10 frame
In the planning stages of the swap and was wondering if it would fit. Thinking of a small vacuum booster.
Nick
Cautrell05 is offline   Reply With Quote
Old 06-11-2015, 01:46 PM   #2
Black93GT
Black93GT's Avatar
Re: Frame mounted M/C with S-10 frame
http://www.code504.com/complete-brak...rame-swap-kit/
Black93GT is offline   Reply With Quote
Old 06-11-2015, 02:59 PM   #3
mr48chev
mr48chev's Avatar
That unit could be adapted to most of the "home done" frame swaps that aren't using their kit with a bit of ingenuity and fabricating.
You have to have the cab setting up off the frame at the right distance to make it work though.
The cost looks a bit high until one studies it a bit and sees bracket and pedals, booster, master cylinder and the combination valve all set up so all you have to do is put it in place and connect your brake lines. For a lot of guys who don't get a lot of hours to spend on their trucks each week that might not be a bad deal at all.
My ongoing truck projects:
Old 06-11-2015, 04:40 PM   #4
Black93GT
Black93GT's Avatar
I just ran across that yesterday. You could use a hydro-booster from an astro van or calculate the size of the master for manual brakes.
Old 06-11-2015, 05:57 PM   #5
steve aleve
That is what I am going to do. Here is a pic of the astro hydroboost mocked up in place.
steve aleve is offline   Reply With Quote
