Ididit column install '72 k10
Hey guys just curious how difficult this actually is. All the research ive done online it looks like people are putting them in on new builds. do i have to remove the power brake system, dash, etc? Just looking for someone that has experience... this forum is great. Thank you!
Re: Ididit column install '72 k10
If you have everything for the install. It should be fairly straight forward. If you are handy.... It shouldn't take more than an hour to swap a direct fit Ididit column.
You don't have to remove anything except a trim piece under the dash and the column itself. Good luck I would rate it as one of the easier projects.
