![]() Join Date: Feb 2015
Lower Ball joint issues...
Re: Lower Ball joint issues...
Were the original ball joints you removed still riveted in? Or were they bolted in?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
This is the lower press in joint
Posted via Mobile Device |
Yeah.....sorry.......not enough coffee in the system yet. I'm thinking the uppers. I do know that if the bottoms have been replaced multiple times I have seen them just about fall out.
I have seen many that were tack welded in.
I hear you on the coffee! The ones that were in were in nice and tight ...had to press em pretty good..I'm getting some moogs from car quests at noon to see
Replacing the uppers and lowers on mine today with Moogs. Will be grinding off the rivets on uppers and getting a loaner press for the lowers and hope all goes as planned.
You might have to go to an oversized ball joint to correct the issue. They should be a tight fit.
Post Whore
![]() Join Date: Mar 2013
Used stock style moogs ball joints on my a-arms....upper ones were fairly easy coming out and going in but the bottom ones...sheesh! lol Sledge hammer to get those in. But they're tight.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
You will want to rent the ball joint press from your local parts store. It will press the old ones out and also install the new ones. Made the job a breeze!!! J
The carquest joints were also too small ..I'm not sure what to do as I have drop spindles for a 73-87
This appears to be the oversized lower ball joint that Carquest shows since that's where you posted the last part coming from. I'd double check though just to be sure. It wouldn't let me punch in anything older than 1975, so I used 75 c-10 chevy 5.7l as the reference. #505-1021OS (oversized)
http://www.carquest.com/webapp/wcs/s...8682?acesApp=1 I also use Red Locktite on my lower ball joints. I've never tacked a set in personally, but have heard a lot of people who have and have seen quite a few done that way.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-10-2015 at 01:15 PM. |
#13 |
That's perfect..thank you
#14 |
No problem. You'll get it resolved in the long run.
#15 |
I was thinking I might tack them in...the guy at the parts store said the oversized one crosses to the ones I already bought....not sure if that's the computer talking or not
#16 |
Carquest shows 505-1021 for the standard lower and 505-1021OS for the oversize. Whats the original part # that you got?
#17 |
He crossed to moog k6117T
#18 |
Never Ending Projects
I ran into this decades ago where the oversized one were still not tight in the arm. It was suggested that I take the arms to a welder who could run a weld bead around the outer edge of the hole, which would cause the hole to shrink smaller. Sure enough it worked and never had a problem after that.
Just another idea to throw out there.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#19 |
Thank you...along the top?
#20 |
Found these but unsure on quality
#21 |
No, the underside of the arm. Flip that over and the lip that the ball joint presses into, around the outside of that (not the area where the ball joint actually touches).
#22 |
I like that idea...I found oversized ball joints for 23 bucks each from classic industries. just so happens napa sells the same joint under the same part number....0025 oversized...if it gets me close ill lay a bead around that lip as you say..thank you for your help
#23 |
![]() Join Date: Feb 2014
Moog web catalog says it should be a K6023. Moog tech support says the K6023 is part of their problem solver line. It is made OS to compensate for the wear in the lower control arms.
http://www.moog-suspension-parts.com...10_pickup_1963 Good Luck! Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
#24 | |
#25 |
Which control arms are you guys using and which spindles will the k6023 fit? I am using the 63 control arm with 73-87 drop spindles...thank you!
