Door Lock Clip
My door lock clip keeps falling off... Was curious if anyone else has this issue?
My thoughts are just get a couple dabs of silicon to help give it more of a semi permanent hold or order a new clip...with the risk of it sliding out... Thoughts?
'71 sb, 406, 350th, boss rims, nitto tires |
Re: Door Lock Clip
Probably just need a bit more bend in the clip itself as that is what creates the pressure to hold it in place. I would grab it with some pliers and bend it some with needle nose pliers.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Re: Door Lock Clip
Junk yard..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Door Lock Clip
Thanks guys. I have bent it to make it seem more likely to hold, but the metal is pretty soft... So it doesn't hold that well... Anyway... I think I might try a spot of silicon to see of that works.
#5 | |
The Older Generation
Re: Door Lock Clip
The originals are tempered steel the repo's aren't. If you want an original one PM me your address and I will send you one.... LockDoc
