steerin box need help ASAP.
Hey guys trying to get my steering hooked up and ran into a snag. I counted 30 splines on the shaft and it measured at 3/4. I ordered a 3/4 DD x 30 spline u-joint and it doesn't fit over the shaft of the steering box. Do I have something that isn't normal? Or am I measuring wrong. I counted the splines multiple times coming up with 30. It is a 70 c10 w/power steering BTW.
#2 | |
Re: steerin box need help ASAP.
Paddle faster, I hear banjo's... Last edited by 1stGrumpy; 06-10-2015 at 08:17 PM. |
I definitely counted 30 again just now but I measured in better light and it seems to be a tad over 3/4".
It should either be a 3/4" - 30 or a 13/16" -36.
Paddle faster, I hear banjo's... |
"...ordered a 3/4 DD x 30 spline..."
While it seems it might fit, you don't have a DD (double D) shaft. The box shaft is a D (think of the flat on the shaft as the flat on the D). DD has 2 flats. Why do you need expensive aftermarket parts? |
Good catch! I looked at that picture a dozen times and it never registered!!!!
Yes the new steering shaft is 3/4 dd and the box shaft is what I thought was a 3/4 30 spline. So I ordered the correct conversion joint. Yes the shaft on the box has a flat spot/D shaped. Do they make an aftermarket joint that is D-shaped on one side and 3/4 DD on the other? I'm installing an aftermarket tilt that has a 3/4 DD on the end and need to connect to steering box. Not a cheap way to connect this that I know of.
check out borgeson u joints ...if anyone has one they should
1970 short step c10 leaf spring 454 |
#9 | |
