Old 06-10-2015, 08:14 PM   #1
UNHLAW2016
OEM Wheel Question 79k20
As I have mentioned in previous posts,, I just purchased a nearly original 79 k20 from the local fire Company. I would like to return the truck to full stock. I am trying to determine which wheels and wheel trims the truck came with. The only information I have is this. (From the build sheet) The truck came with 10x16.5 tires and 1p06 bright metal wheel trims.
Any advice?
UNHLAW2016 is offline   Reply With Quote
Old 06-10-2015, 10:02 PM   #2
SS Tim
SS Tim's Avatar
Re: OEM Wheel Question 79k20
10.00 tires were factory mounted on 8.25 x 16.5" steel wheels. Your SPID is listing the optional P06 trim rings. Being a K20 it should have chromed hub caps (P03) as standard equipment.
SS Tim is offline   Reply With Quote
Old 06-10-2015, 10:11 PM   #3
UNHLAW2016
So this means my truck had caps and rings?
Old 06-10-2015, 10:26 PM   #4
UNHLAW2016
Can standard tires be put on this rim or does it make more sense to look for a 16inch steel rim?
Old 06-10-2015, 11:52 PM   #5
nonstop
Look for the 16 inch - 16.5 is getting very hard to find and is obsolete. I am keeping an eye out for 16's to replace my 16.5's.
nonstop is offline   Reply With Quote
