Old 06-11-2015, 12:30 AM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
parking brakes...
whats up guys..wanted to get yalls opinion/advice..
got a 63 swb.. are any of yall using aftermarket parking brakes..i dont like the look of the old handle under the dash...i was thinking of going with a lokar set up..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 06-11-2015, 08:44 AM   #2
earl84
Re: parking brakes...
Can't help you with this, just an interesting observation on how people's opinions differ. I freakin' LOVE the stock parking brake handle, to me it's one of the most iconic features of these trucks. But, that's MY opinion and I kept it on my truck. Good luck with whatever you decide.
earl84 is offline   Reply With Quote
Old 06-11-2015, 11:21 AM   #3
wayno
I'm with Earl on this one - and I am no purist by any means - cutting up my inner fenders... lowering etc. I'm going out of my way to keep the parking brake handle because I love the look - I'm also going to run an old deluxe steering wheel as well. No wrong answer here though.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 06-11-2015, 11:45 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is some info on using a brake pedal mechanism from a mid-80s foot pedal assembly:
http://www.persh.org/pickup/misc.htm
Which I was considering, if I can't find a brake handle.
Old 06-11-2015, 06:10 PM   #5
Blue666(2)
I was not crazy about the brake handle location on the 1/2 ton truck but I liked it on the 1 ton trucks. This picture shows my first whack at relocating the handle. I used a handle from a 1 ton. I have since moved it back and even with the gear shift.
I made a mount for the rachet and handle from 4" channel stock. This mounts to the bottom of the high hump cover. The bigger problem is routing the forward brake cable. I moved mine to the inside top of the swing arms. The cable now goes through the cross member close to the drive shaft.
I used an emeregency brake cable junction bracket to gather and align the cable ends. I pull the center section with a rod to the 1 ton handle.
This web page has some product to help you. http://www.controlcables.com/parking-brake-hardware/
If you search this forum for Lakeroadster, he also used a floor mounted brake handle.
Blue666(2) is offline   Reply With Quote
Old 06-11-2015, 06:49 PM   #6
Blue666(2)
Here's a picture of the of the 2nd attempt. This handle sits back even with the gear shift and has a smaller hole through the high hump.
It rides on two rails (1 x 1 angle iron) to span the high hump front to back and the sheet metal is adjusted to accept the rails.
A third version, when I get around to it, will eleiminate the rails and mount the rachet & handle direcly to the high hump panel.
Old 06-12-2015, 02:03 AM   #7
PowerdbyChevy79
looks good brother..
1966 C10 "Mary"
Old 06-12-2015, 02:04 AM   #8
PowerdbyChevy79
ya im still debating on it.. im not finding any after market right now..i may go the route of blue666 ..but we will see.. thx for the input guys
1966 C10 "Mary"
Old 06-12-2015, 09:04 PM   #9
The Rocknrod
Moderator
Here is another idea:
http://persh.org/pickup/DonsEBrake.htm
Old 06-12-2015, 10:55 PM   #10
Blue666(2)
This type e brake control would fit tight under the dash. You pull out to engage and rotate 90 degrees to release. Simialr units were used in Jeeps and import trucks.
https://www.cal-mustang.com/MUSTANG-...MBLY-C880.aspx
Old 06-13-2015, 01:48 AM   #11
Slow Build
Slow Build's Avatar
I haven't done any research yet but I have been thinking about going to a pedal to replace the handle. In my case I would like to extend the dash down a few inches (examples below) to hide the wiring and mechanicals. Just clean it up a little bit. I was planning on doing some measurements on a 67-72 setup since (at least the one I took pictures of but didn't measure) also have the vent, but with an easier to use handle, so there should be clearance. As I said I'm only in the preliminary thought process so it may not work. If someone else has tried this I like to here if it's possible. If so it would be a lot less than the aftermarket alternative.
I like that setup that Blue666 has. Looks like your ready for the drift competition.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-13-2015, 04:10 AM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
I fell in love with the Orscheln “over-center” hand brake in Vietnam. All of the military vehicles had one. They were easy to use, and the tension was easy to adjust right at the knob on top. I couldn’t figure out why they weren’t standard on regular production cars. It turns out they were installed on Dodge trucks and Chevy step vans for many years.
I bought this one for a Chevy step van from this outfit for $37.93 brand new:
https://www.millsupply.com/workhorse...36275&cs=1+133
It bolted right up to the stock cable setup and is much easier to operate (compared to the stock GM handle) for a guy with a bad back like me. The full installation can be seen on page 74 of my build thread.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
