Old 06-11-2015, 09:24 AM   #1
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
72 402 and AC items
ALL SOLD Thanks for looking!
I just finished an LS swap on my 72 Suburban. I ended up with a few extra parts that I had intended to store for a rainy day. Well I'm already tired of tripping over it all. So listing it here to see if anyone wants any of it.
I have 2 402 bare blocks. One needs bored, other needs a sleeve in cyl 7.
This is the block that needs a sleeve the other has the same suffix code
They both have the same casting numbers,
Here is the reason the first block needs a sleeve. Casting flaw...
To go with these blocks, I have the following
2 cast cranks, one needs turned other needs polish
16 Pistons and Rods, 15 rod caps....(one was missing off of second engine)
2 pair of heads, I'll provide the casting numbers later, stock round port.
1 pair of Valve Covers
1 Pan
1 stock intake
1 Rochester 4BBL
1 Starter ( newer reman )
1 Alternator
1 AC Compressor
I also installed vintage air, and have the underhood and underdash AC/Heater items. I retained the indash control, but all cables are there and covers are in great shape. Lines from compressor to the condensor, to the evap. I will provide pictures of that as well.
I would like to sell the engine items as a whole, package deal $600, as far as the AC goes, I would like $200 for the AC items as a package deal.
I live in Central Illinois, prefer local pick up, but I am willing to meet you with in reason, I'll travel your direction if it helps.
Thank you,
Brad
bowtieguy79 is offline   Reply With Quote
Old 06-11-2015, 09:32 AM   #2
Dirt's72
Re: 72 402 and AC items
I'd be interested in the carb if you would sell seperate.
Dirt's72 is offline   Reply With Quote
Old 06-11-2015, 09:40 AM   #3
bowtieguy79
Ephesians 2:8
You know, If you folks see something you want separate, feel free to make me an offer.
Old 06-11-2015, 10:44 AM   #4
Dirt's72
Brad can you tell me what numbers are stamped on the carb and how the throttle shafts feel?
Old 06-11-2015, 10:55 AM   #5
bowtieguy79
Ephesians 2:8
Sure will, I'll grab it tonight and check it out.
I have this pic of it on the engine. It seems to possibly be a Olds/Pontiac carb. Reason I say that is the front style gas line hook up, most trucks I've messed with are side gas line ( at least the 78-79's I've messed with )
Old 06-11-2015, 11:13 AM   #6
Dirt's72
Thanks. Nice burb you have there!
Old 06-11-2015, 02:31 PM   #7
crumc10
crumc10's Avatar
Bowtieguy79, by chance are you going to the Goodguys show in Columbus, OH next month? I would be interested in your engine package deal, but I live in Northeast TN.
crumc10 is offline   Reply With Quote
Old 06-11-2015, 02:33 PM   #8
bowtieguy79
Ephesians 2:8
I just looked it up, my boy has a baseball tournament that weekend. If it is something you are serious about, I could meet you. PM me we can talk more about it.
Old 06-11-2015, 09:01 PM   #9
crumc10
crumc10's Avatar
PM sent.
Old 06-11-2015, 09:22 PM   #10
kingstrider
kingstrider's Avatar
Interested in the underhood AC items, please send photos
kingstrider is offline   Reply With Quote
Old 06-11-2015, 10:20 PM   #11
bowtieguy79
Ephesians 2:8
Here are a couple pictures. Also the shaft has little to no slop, pretty tight. It worked well, even the choke was happy.
I took a video of me wiggling the throttle shaft, it's uploading.
Old 06-11-2015, 11:31 PM   #12
Mapearso
In line after kingstrider for all the under hood AC stuff
Mapearso is offline   Reply With Quote
Old 06-12-2015, 09:14 AM   #13
bowtieguy79
Ephesians 2:8
Here are the photos of the underhood AC. I have the heater core as well, just failed to get a photo.
Old 06-12-2015, 09:15 AM   #14
bowtieguy79
Ephesians 2:8
noted
Old 06-12-2015, 10:52 AM   #15
Dirt's72
Brad thanks for the carb pics. Looks like it is original to a 76-77
454 gm truck. I'm wanting 72 specific. I would try the square body parts forum I bet somebody there could use it. Thanks.
Old 06-12-2015, 11:16 AM   #16
bowtieguy79
Ephesians 2:8
thanks for the info!
Old 06-12-2015, 02:23 PM   #17
Mapearso
bowtieguy79 --
I'm definitely interested.
Was this working when removed?
Is it a complete setup? If not, what is missing?
Thanks!!
Old 06-12-2015, 02:29 PM   #18
bowtieguy79
Ephesians 2:8
bowtieguy79 --
Thanks!!
It was intact before I removed it. I vac'd down the system and it would not hold vacuum. It is missing the indash control only. The rest is there. Less the T's that go to the rear ac, as stated before.
Old 06-12-2015, 03:05 PM   #19
Mapearso
Well, I have the indash control, so that's covered.
Does this include all the brackets to attach to the engine?
Or is it just the plumbing itself but not the hardware
Sorry for all the questions, just trying to clarify
Thanks again
Mark
Old 06-12-2015, 03:29 PM   #20
bowtieguy79
Ephesians 2:8
Thanks again
Mark
I have the brackets for compressor etc.... , bolts... there is a pile of bolts... lol so no to the bolts. The compressor might as well go to, at least be a solid core for a new one.
Let me gather it all up and make a list of what is there, and get a good photo of each piece tomorrow. We have baseball tonight and tomorrow morning.
Old 06-12-2015, 08:10 PM   #21
Mapearso
OK. Standing by
Thank you
Old 06-12-2015, 09:17 PM   #22
gs1969
gs1969's Avatar
Did you use the 72 engine frame stands for your swap? If not, for sale?
gs1969 is offline   Reply With Quote
Old 06-12-2015, 09:23 PM   #23
bowtieguy79
Ephesians 2:8
I did not use the BBC stands, make me an offer, no rubber mounts included.
Old 06-12-2015, 09:58 PM   #24
gs1969
gs1969's Avatar
You have only the frame towers? And there for 72, any pic's?
Gary
Old 06-12-2015, 11:12 PM   #25
bowtieguy79
Ephesians 2:8
Gary
Yes 72 big block mounts. Stands and mounts, ready for replacement rubber isolators. I'll get you a pic some time over weekend
