06-11-2015, 02:48 PM | #1 |
What Panhead Bar/Mount are you using?
I changed my HO32 rear out for a GM 12 bolt, (from 81-87) need to add a panhead mount back to Diff and get an adjustable panhead bar. What are you guys using.
Truck is a 62, it has been lowered 3" with lowering springs. Appreciate the suggestions! Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
06-11-2015, 03:22 PM | #2 |
It's Better With Nitro
Re: What Panhead Bar/Mount are you using?
A long time ago, I fabricated and welded my own bracket on the back of the passenger side trailing arm combined with an adjustable track/panhard bar that I also fabricated. Then a few years later, Early Classic started offering this brilliant kit: http://www.earlyclassic.com/catalog....20track%20bars
I would just go with the Early Classic kit.
06-11-2015, 04:14 PM | #3 | |
I seen a thread where Porterbuilt had a track bar that mounted to the trailing arm(s) but the pics weren't detailed enough for me to see all the contact points and mounts. Anyone used there kits? Any pics of one installed? Thanks
06-11-2015, 04:24 PM | #4 |
I used the ECE kit above on my '63. Just note, you have to relocate the factory frame mount. Not a big issue.
06-11-2015, 04:25 PM | #5 |
not the best pic, but my PB bar is mounted outside the frame rail on drivers side, and to the trailing arm on the passenger side. |
06-11-2015, 04:26 PM | #6 |
I went with a similar kit from CPP.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-11-2015, 08:04 PM | #7 |
this one is from early classic(if you have a fat diff cover)
06-11-2015, 09:01 PM | #8 |
im using the CPP Deluxe Kit, that moves the mount to the lower passenger side on the control arm.
its a damn nice kit.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
06-11-2015, 09:27 PM | #9 |
here is my CPP kit I had to modify it a bit
06-12-2015, 01:06 AM | #10 |
Thanks for all the replies and pics, I ll let you know what I wind up using.
Pappyx4! Posted via Mobile Device |
01-02-2016, 02:31 PM | #11 |
But Found Her 25yrs Later!
Any updates?
My 65 is on a 62 frame I also upgraded from an Ho32 to a 12-Bolt. and I also want the adjustable one that mounts to the passenger trailing arm.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-02-2016, 08:12 PM | #12 |
Porterbuilt!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-04-2016, 09:03 AM | #13 |
No updates on the panhead bar/mount on the 62.
In the last week I just got everything buttoned up so I could actually move it out of the garage on it's own power. Panhead bar/mount are next in line... Thanks, Pappyx4!
