Old 09-04-2003, 02:44 PM   #1
jasonrog
jasonrog's Avatar
serprntine system
I have a serpentine system off a 90 truck. I am ready to install it but have a question. The new alternators wiring is slightly different. It still has the heavy cable that bolts to the back of the alternator, but the plug connector has only 1 small guage wire. Any suggestions? Wiring diagrams?
Jason
jasonrog is offline   Reply With Quote
Old 09-04-2003, 02:56 PM   #2
cdowns
cdowns's Avatar
don't forget to change the water pump
Old 09-04-2003, 03:02 PM   #3
jasonrog
jasonrog's Avatar
why change the pump? Reverse rotation?
Old 09-04-2003, 04:46 PM   #4
nate68
after workin on a car with serpentine i am glad i diecided not to do a serpentine setup. pain in the butt
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-05-2003, 02:13 AM   #5
jasonrog
jasonrog's Avatar
Why are guys installing them then?
Old 09-05-2003, 05:18 PM   #6
nate68
it's a trend. it's expensive for not htat much in hp gain
i personally don't like working on serpentine systems.
Old 09-05-2003, 06:37 PM   #7
cableguy0
serpentine systems are easier to deal with the belts last longer and dont slip. vbelts come want to come apart and slip terribly at higher rpm whereas as a serp belt system doesnt. a serp belt requires no tightening because it has a tensioner the belt usually needs replaced every 60 thousand miles and thats it. i think you can just use your alternator in the bracket just swap the pulleys over. im almost positive both have the 12 oclock 6 oclock bolt pattern meaning the mounting holes are directly across from one another
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-05-2003, 10:32 PM   #8
jasonrog
jasonrog's Avatar
I have everything that came with the serp system, alternator, ps pump, and water pump. Should I do the swap or not. It won't cost a penny except for a water pump gasket.
Old 09-05-2003, 11:26 PM   #9
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
The diffrence in the alternator is it is a one wire hookup, look in the faq board for a wiring diagram to hook it up.
GMC JUNKIE TOO is offline   Reply With Quote
Old 09-06-2003, 01:54 AM   #10
jasonrog
jasonrog's Avatar
I looked through the faq and found nothing.
Old 09-06-2003, 08:33 AM   #11
fast71
Drive it like U stole it
fast71's Avatar
try this http://www.chevelles.com/techref/tecref14.html
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 09-07-2003, 01:03 AM   #12
jasonrog
jasonrog's Avatar
I got most of the swap done in about two hours. Unbolt and bolt back on. Very simple. One problem I ran into is the old water pump had a fitting on it for a heater hose. The new pump does not. Where can I hook up the second heater hose? I can't leave it disconected for too long 'cause it is starting to get cool gere at night. A couple of more weeks and I will need the heat.
Jason
Old 09-08-2003, 10:29 AM   #13
jasonrog
jasonrog's Avatar
Since the water pump was changed, does the fan need to be changed as well?
Old 09-08-2003, 11:01 AM   #14
Primed67
Primed67's Avatar
If you are wanting to pick up horse power through your pulleys why not go with under drive pulleys. I would recommend a 30%.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 09-08-2003, 12:34 PM   #15
jasonrog
jasonrog's Avatar
I am not after the power. The reason I did this was that my ps pump died on me and I had the whole system (Alt, brackets, pullys, ps pump, water pump, belt, etc.) off a new truck sitting in the garage. It was a lot cheaper than buying a new pump.
Jason
Old 09-08-2003, 01:18 PM   #16
Primed67
Primed67's Avatar
I read you loud and clear. I probably would have done the same thing if I was in your situation.
Old 09-08-2003, 05:43 PM   #17
SCOTI
SCOTI's Avatar
Most late model systems that utilize the serpentine set-up have the second heater hose fitting in the radiator.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-11-2003, 01:46 AM   #18
nate68
serpentine systems wouldnt be that bad as long as you are running electric fans.
Old 09-11-2003, 12:56 PM   #19
69sixpackbee
Serp. systems are put on by the mfg's. for one reason and one reason only..to save manufacturing $$. We are stuck with 'em now. Besides the newer designs would be a PITA to access the belts separately anyway.
69sixpackbee is offline   Reply With Quote
