Back up lights stay on while driving...help
I'm having trouble with my b&m hammer shifter in my truck. When I put it in reverse and then into drive my back up light stay on...I actually have to wiggle the shifter back n forth for it to go out. Sometimes it'll stay on in park too. Does anyone have an idea what could be the issue?
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
Re: Back up lights stay on while driving...help
You most likely need to adjust the micro switch the runs the back up lights.
try loosening the screws while in park with key on and move the switch around till they shut off. if you can't you will have to shim it or bend the switch mount a tad.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
I'm trying to figure out this shifter...the shifter is in drive and the back up lights are on...im not sure what the reverse switch is on the shifter and where it is...can someone tell me what im looking at here?
there are two micro switches one the drivers side of the shifter. the top one is the reverse light and the one under it is the neutral safety switch. The top one should be wired to your reverse light circuit. If the micro switch is too close to the detent plate the lights will stay on. and obviously if the neutral safety switch is adjusted the same (which it looks to be) you will be able to start the engine in any shifter position. you need to move those switches away from the detent plate about 1/16th to 1/8th inch.
thanks tito...had a friend of mine look at it and he just bent the metal contact back a little bit and now it don't stay on anymore. had to get that fixed...got pulled over by the cops for it.
I'm glad you got it handled.
