06-12-2015, 12:20 AM | #1 |
swp brackets and pulleys
I am selling an alternator bracket set for a small block short water pump set up, plus crank pulleys and water pump pulley. This will mount the alternator on the drivers side, as our trucks were from the factory.
The long alternator bracket looks like it was repaired at some point. You can see the weld in the pictures. It looks like it could be ground down better and then would not cause any problems. It's also a little bent, but should be able to be straightened out. I assembled these parts to convert my late 70's motor over to a short water pump setup, and then ended up finding the LT1 motor and trans, which changed all my plans. The water pump pulley is part #3751232 BB, and the crank pulley is part #3995646 AH Pulleys are sold, pending payment. Alternator brackets are still available for $30 shipped, CONUS. Postal money order or Paypal (add 3.5 percent to cover fees)
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 06-13-2015 at 11:25 PM. |
06-12-2015, 12:35 AM | #2 |
Re: swp brackets and pulleys
No pics? Does this set put the alt on the passenger side?
1967custom |
06-12-2015, 06:38 AM | #3 |
No, drivers side. It's for a short water pump. I'll post pics on a little while
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
06-12-2015, 08:30 AM | #4 |
Pics of upper bracket
06-12-2015, 08:31 AM | #5 |
More of the upper bracket, and a couple of the lower bracket
06-12-2015, 08:32 AM | #6 |
crank pulley
06-12-2015, 08:37 AM | #7 |
And the water pump pulley
06-12-2015, 05:13 PM | #8 |
ttt
06-12-2015, 08:39 PM | #9 |
I would be interested in all the pulleys. How much shipped to 44805 if you would seperate from the brackets?
Mike Wilson |
06-12-2015, 10:44 PM | #10 |
How about $35?
06-13-2015, 12:00 PM | #11 |
If people want to separate these, I would do $35 shipped CONUS on the pulleys, and $30 shipped on the alternator brackets.
Thanks!
06-13-2015, 12:18 PM | #12 |
06-13-2015, 12:18 PM | #13 |
06-13-2015, 11:26 PM | #14 |
Pulleys sold to Chevy Fan Always pending payment.
Alternator brackets are still available for $30 shipped, CONUS. Please add 3.5% if paying by Paypal. Thanks!
06-14-2015, 11:54 AM | #15 |
ttt
06-15-2015, 11:29 AM | #16 |
Chevy Fan Always,
Pulleys are going out via UPS today, here's the tracking info. 1Z903AF20394502290 Thanks!
06-18-2015, 09:02 PM | #17 |
