Old 06-12-2015, 12:34 AM   #1
russellrox
Exact frame measurements needed for converting a longbox truck to shortbox
was wondering if someone knows of the exact location and measurements needed to convert a longbox frame to a shortbox.
russellrox is offline   Reply With Quote
Old 06-12-2015, 01:02 AM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Exact frame measurements needed for converting a longbox truck to shortbox
Exact?
Well, I can say 12" out of the front and 8" out of the rear....pretty simple
the 12" is taken from the frame under the cab...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-12-2015, 01:41 AM   #3
russellrox
was looking for measurements on where to cut the step in the center , how much behind the rear cab mount, where is the reference point to measure back from.
Originally Posted by ol_skool_chevy View Post
Exact?
Old 06-12-2015, 02:59 AM   #4
padresag
you might find some pictures in the faq section
ron
padresag is offline   Reply With Quote
Old 06-12-2015, 09:11 AM   #5
Lugnutz65
Lugnutz65's Avatar
. . . . the 12" is taken from the frame under the cab...
Pardon me if I'm just not thinking, but removing 12" from the frame BENEATH the cab doesn't make sense. Longbed and shortbed trucks are identical from the rear of the cab forward. Right?
I'm thinking you meant remove 12" from behind the cab.
These threads might be helpful
http://67-72chevytrucks.com/vboard/s...d.php?t=499189
http://67-72chevytrucks.com/vboard/s...d.php?t=333241
http://67-72chevytrucks.com/vboard/s....php?p=4881959
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
http://67-72chevytrucks.com/vboard/s...d.php?t=275426
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-12-2015, 10:38 AM   #6
russellrox
I have another decision to make lol, I have a perfect long box that is on the truck now, do I cut it down to a shortbox, or do I use my existing short box and do the rust repair and bodywork and sandblasting on it. The longbed has 25000 miles on it, original bed wood, in unreal original condition, my shortbed is dented up and has been previously patched at some point, I also have to replace the front panel, tubs, and tailgate. Not sure what is more expensive.
Old 06-12-2015, 11:28 AM   #7
donthekawguy
donthekawguy's Avatar
You have to take it out from under the cab. There isn't enough frame to get it anywhere else. The 67-72 you can do it from behind the cab with the cab still on the truck.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-12-2015, 09:14 PM   #8
argonaut
argonaut's Avatar
Its not just the available length. Both long bed and short bed pickups have the same length trailing arms. So best place to remove the 12" is from the section of frame in front of the center crossmember that the trailing arms mount to. Then just relocate the rear cab mounts and the front bed mounts 12" back. Otherwise if you cut behind the cab mount, you'll need to shift the crossmember 12" forward.
Unless it is a 4x4 or a GMC with rear leafs. Then you can cut right behind the rear cab mount.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-13-2015, 12:06 AM   #9
Captainfab
60-66 Nut
The best place to remove the 12" is under the cab. just a little ways forward of the rear cab mounts. This also allows you plenty of room for the reinforcement plate on the inside of the frame. Then you just have to move the rear cab mount brackets 12" back. And of course trim 8" off of the back of the frame.
