Old 06-12-2015, 01:23 AM   #1
69vetteside
69vetteside's Avatar
does anyone work @ RIDETECH
I have sent emails to ridetech including sales and have got no answers regarding the coilover strongarm kits for the 69 C10.
All i want to know is what coilovers do i need for cruising and some drag racing
IE model numbers and spring rates.
69vetteside is offline   Reply With Quote
Old 06-12-2015, 01:42 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: does anyone work @ RIDETECH
We do have at least one guy here from Ridetech. look over in the Suspension Marketplace, they posted specials and stuff before.
As for your question though, there really isn't a simple answer for that. Actually calculating the spring rate involves a bunch of math, which I'm not really qualified to explain. That being said though, when you go to ridetech's website and select the coilovers for the 63-72 from their menus...the only list one part #. http://www.ridetech.com/store/coilov...djustable.html
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-30-2015, 04:09 PM   #3
chase@ridetech
chase@ridetech's Avatar
I work at Ridetech Let me know what email you sent your questions to and I will get it taken care of.
In regards to the coilovers you need for your truck, what motor and transmission are you using? If you are running a small block, or LS motor, our standard kit would work best. If you are using a big block I would bump the front spring rate up some. I would use the HQ series so you can adjust your dampening for the track and for the street.
chase@ridetech is offline   Reply With Quote
Old 06-30-2015, 11:18 PM   #4
69vetteside
chase hi.sorry bud but i sent an email to bigmike(with the green truck) thru this site and sent one to the sales email as well on the ridetech website.
anyway i am getting some answers now.As to what engine its a SBC now but plans have changed and i will be going the blown bigblock route and t400.
will order thru Summit and i will get the HQ shocks.what rate springs do you suggest for the front with BBC.
it will mainly be street driven but i want to go street drags over here wednesday nites and nostalga drags..
cheers
Old 07-06-2015, 08:53 AM   #5
chase@ridetech
cheers
I would use the 900lb spring in the front on a blown big block. that will give you a good ride quality and the HQ will have enough adjustment to get out and do some racing!
Old 07-07-2015, 10:47 AM   #6
69vetteside
thanks Chase.can you tell me what spring rate for the sbc as well (money became tight ,no bb for a while)Also what length spring goes with the 11333510 HQ coilover.
cheers
Old 07-07-2015, 05:33 PM   #7
chase@ridetech
cheers
on the small block kit it gets an 8" 800lb Spring
Old 07-07-2015, 05:34 PM   #8
chase@ridetech
If you decide to do the big block later you can just change out the springs, the run 75.00 each and all of the other parts are the same.
Old 07-07-2015, 09:15 PM   #9
69vetteside
thank you
Old 07-09-2015, 01:05 PM   #10
chase@ridetech
No Problem! Let me know if any questions come up.
Old 12-01-2015, 11:55 AM   #11
chase@ridetech
69Vetteside, how did your install work out?
