Old 06-12-2015, 12:01 PM   #1
BigSix
Plastic Tank? In or under is OK!
Ladies and gents. Going diesel and my metal tank is rusty inside.
Is there a plastic inside tank option?
Is there a preferred plastic Suburban or other style tank for underneath?
BigSix is offline   Reply With Quote
Old 06-12-2015, 12:36 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Plastic Tank? In or under is OK!
You couldn't use a new steel fuel tank with diesel?
$169
http://www.ebay.com/itm/Goodmark-414...e4f03e&vxp=mtr
Old 06-12-2015, 12:37 PM   #3
BigSix
Could but want to avoid corrosion at the top of the tank where there is air...injection pumps and injectors break the bank if the smallest bit of that gets in. Plastic or aluminum are really the only way to fly. Plastic will probably be a fraction of the cost though.
Old 06-12-2015, 12:41 PM   #4
The Rocknrod
Moderator
Cat 1 Micron filter.
I use one on my engine and a Donaldson 3 micron at the fuel tank in my LMM.
Of course my fuel tank is Poly as well, so your headed in the right direction.
Old 06-12-2015, 12:43 PM   #5
BigSix
I like that. So you still have metal in cab and hung a filter underneath and one on the stock cummins mount?
Old 06-12-2015, 12:51 PM   #6
The Rocknrod
Moderator
No - My LMM is a 2009 Silverado Duramax Diesel with a Poly tank.
I conducted a search but havnt yet found a poly tank for the C10. I have a aluminum tank I have yet to use . . .
Old 06-12-2015, 12:51 PM   #7
siggyfreud
siggyfreud's Avatar
I think he's saying he uses a filter, but his tank is plastic as well.
siggyfreud is offline   Reply With Quote
Old 06-12-2015, 12:53 PM   #8
BigSix
Oh yeah I have a filter on the cummins but a metal tank is still going to corrode and impede flow more than a plastic.
Anyway - back on topic. Plastic tanks.
Old 06-12-2015, 01:22 PM   #9
Improbcat
Improbcat's Avatar
Try going to Tanks Inc and searching "poly", they have a variety, one might work.
I noticed this one in particular. it is 34.5" x 19" x 8.5" and comes in left & right fill. (note I have no experience with this tank/site, just trying to help)
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 06-12-2015, 03:57 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I used a similar tank to that from Tanks Inc. in my '68 long bed. I moved the rear crossmember back and removed the spare tire brackets. Fit good. Haven't used it yet but I know it won't rust.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-12-2015, 04:04 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
For what it’s worth – I had a poly tank under my 46 Ford sedan back in the late 80’s. I no longer remember who made it, but it worked great and was inexpensive. It also sagged badly during the heat of summer so I ended up putting multiple van straps under it to give it a better safety margin.
When considering the installation just plan for additional support underneath as these don’t have the rigidity of a metal component.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-13-2015, 10:43 PM   #12
BigSix
That looks good. Are you thinking this would be good to mount right behind the cab on the frame rail?
Old 11-14-2015, 11:08 AM   #13
chevy_mike
chevy_mike's Avatar
If you are talking between the frame rails, behind the cab, no this won't work as you have the driveshaft running through there. If you are talking on the outside of the frame, this is way too big to fit there.
Behind the rear axle is the only location this is going to fit unless you mount it inside the bed itself.
