Dana 44 carrier
carrier break is 3.73 and 3.92. (3.92's in there now) so what carrier to use? 3.73 and down and it will be an open carrier right? will my spider and side gears fit? does my 61 have 19 or 30 spline axles on the carrier side? forgot to count when i had the axles out for u-joints. all this becouse of rear eaton with 3.38's.
just a used carrier will be fine as long as my spiders and side gears will fit. thanks in adv.
1961 chevy K10 my build is------------61K10 build |
Re: Dana 44 carrier
No experts? can mod's move to eng and drivetrain------
Re: Dana 44 carrier
I think your spider gears should work but im not 100% on that.
Re: Dana 44 carrier
Sometimes it takes more than 4 hrs to get an answer. Patience Grasshopper
Re: Dana 44 carrier
All normal (non jeep jk)d44 side gears will be 30 spline and fit your chevy carrier. 373and numerically lower go on the 373 and down case. 392 and numerically higher go on the 392 case.
Re: Dana 44 carrier
thanks obijun. I have a 3.92 case and will need a 3.73 case for my new 3.31 r&p and my spider and axle gears will fit.
Re: Dana 44 carrier
Do you need a carrier?
Re: Dana 44 carrier
just bought one for $20+shipping but thanks
Re: Dana 44 carrier
Late to the game, but I have a factory d44 rear in my '61 Suburban, with 30-spline axles, and I bought a Jeep take-out posi carrier and loaded 3.42 gears on it.
I'm about to start a '62 4x4 long-step project, and plan to put 3.42 or so gears in it, with posi units in both ends. I'll do some light off-roading, but it's mainly going to be my daily driver and will use it on a couple construction sites and for hunting. With the lock-out hubs, I don't see posi being a problem in the front for around-town driving. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Re: Dana 44 carrier
just found out my $20 carrier is junk as i ordered a new cross pin and it's loose in the carrier----------
Re: Dana 44 carrier
Here's a 30-spline 3.73 posi for $174.
http://www.ebay.com/itm/Dana-44-3-Se...f41c4b&vxp=mtr (not mine) Check any local Jeep or off-road shops that do installations, as a lot of Jeep guys want want steeper gears and get rid of the 3.73-and numerically lower units. -Brad
#12 | |
Re: Dana 44 carrier
Do you live anywhere Marysville? Reason I ask is that there is a guy there who always has stuff on CL for our trucks. You can see his place from the road (hwy 20 I think) on the way to Collins Lake. He is always selling the 1/2 ton (ho 52?) and HO 72 axles, frames etc. For some reason, no sheetmetal but lots of drivetrain parts. Might be worth a look?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#13 |
Re: Dana 44 carrier
Just re read your post. Im a dope. You're only looking for a good Dana 44 carrier right? There's a place in San Jose called Rear End Specialties that has stocked good used carriers when I've swapped gears in the past. The price was right when they were installing a gear set. They may be worth calling. Also, my kid brother has a shop in Loomis as well. He has a truck wrecker right next door that he is pretty tight with. I could ask him to give a call if you like.
#14 |
Re: Dana 44 carrier
thanks 63Gen--I bit the bullet and bought a posi from Rons machine service (new for $275) Loomis is about an hour away. I'm 12mi from hwy 50 in placerville.
