Old 06-12-2015, 08:09 PM   #1
burlapen
burlapen's Avatar
Anybody have measurements for idler arm bracket holes?
I put 1972 spindles, steering box etc on my 63 C10. Apparently the idler arm
Bracket mounts in a different location on the frame. You can see the '63 mounting holes going the opposite direction just to the right of where the new one is c clamped on. Anyone know exactly where I should put the holes for the new setup? I'm afraid if I eyeball it things will get wonky real quick. Thanks.
burlapen is offline   Reply With Quote
Old 06-12-2015, 08:11 PM   #2
burlapen
burlapen's Avatar
I don't know why my pictures are turned sideways again. Here's one more.
Old 06-12-2015, 08:12 PM   #3
burlapen
burlapen's Avatar
Old 06-15-2015, 01:12 AM   #4
cheyenne shortstep
cheyenne shortstep's Avatar
Re: Anybody have measurements for idler arm bracket holes?
I can get them from one of the trucks I have.
cheyenne shortstep is offline   Reply With Quote
Old 06-16-2015, 06:08 PM   #5
burlapen
burlapen's Avatar
cheyenne Shortstep, that would be awesome. I can't seem to find it anywhere else. Thaks.
63 Chevy C-10
My build thread
Old 06-19-2015, 12:37 PM   #6
scottofksu
scottofksu's Avatar
What I did was to attach the pitman arm to the steering box and the center-link, and then the idler arm to the center-link and idler mount. Then I supported the center-link by moving the idler arm bracket so all of the natural "hang" and deflection of the center-link would be incorporated into by measurements when determining where to mount the idler arm bracket. I then used two magnetic torpedo levels - one on the flat spot of the crossmember and one on the center-link to get the bar level. I then measured from the center-link to reference holes on the crossmember to ensure the bar was square with the frame and crossmember. Once I had the center-link adjusted to be square and level, I clamped the idler arm bracket in place and drilled the holes. Make sense?
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
