Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-13-2015, 04:33 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Trailer tires
Radial or bias ply . Looking at G load rage 14 plys for my enclosed trailer
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-13-2015, 07:14 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Trailer tires
Well My enclosed trailer is 24' and has 8 lug 7200 # axles with brakes on both axles . I currently have 235/85/16 10 ply truck tires on it . 3 of the tires are 8 years old . I had one break a cord last year and I put a used tire on it then . Last trip I cut a tire on construction junk . The spare is 3 years old and currently on the ground plus I have a new truck tire I bought last weekend . The tire shop keeps new wheels in stock for about $50 . so ill stow the spare and buy a rim for the new tire and I ordered 4 of these today . There was a thread were someone had tire issues and it got my thinking . Gross weight on my trailer is 8-9000 lbs
http://www.ebay.com/itm/140909517329...%3AMEBIDX%3AIT
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-13-2015, 07:29 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Trailer tires
I had Marathon trailer tires on my enclosed. They have a HORRIBLE reputation (google for some of the horror stories)
I replaced them with Carlsile Traile tires from Discount Tire. The road hazard certs cost like $18 extra per tire. Guarenteed for life of the tread. I asked specifically about dry rot cracking and safety,, they said if the sidewall starts cracking they will replace them FREE down to 40% tread. I'm sure you have the same issue there as we have here in the hear. They crack all to hell LONG before the tread is even showing wear.
Figure i 'bought' the last trailer tires I will every have to pay for.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-13-2015, 11:01 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Trailer tires
I will never wear out the tread on my trailer tires that's for sure.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-14-2015, 11:53 AM   #5
djracer
djracer's Avatar
Re: Trailer tires
As a general rule most trailer tires suck.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-14-2015, 05:24 PM   #6
Blue Rat
Re: Trailer tires
You think trailer tires suck. You should try replacing motor home rv tires. Those get expensive. Lot of times you will never wear out a trailer tire. They just dry rot. Radials are the way to go now.
Marv if they stand behind that warranty when it is time. Consider your self lucky.
Blue Rat is offline   Reply With Quote
