Old 06-13-2015, 05:33 PM   #1
campingman
Brake Question
Spring Retainer that goes in between the Hydroboost and the Master Cylinder broke. Can't fine it anywhere. I put the spring and push rod back in it without the spring retainer and the brakes work perfect. You think it will be ok or should I hunt down a spring retainer for it? Having a hard time finding one. Brakes work perfect after installing the new master cylinder but when I took off the old one, the spring retainer flew out and was broke. the teeth that hold it in was rusted broke. Its a 1975 GMC G3500 Camper
Photo is what im talking about. The washer looking thing with the rubber in the center the pushrood goes through.
campingman is offline   Reply With Quote
Old 06-13-2015, 06:47 PM   #2
campingman
Re: Brake Question
forgot to mention, the push rod goes about 1 1/2 inches into the master cylinder bore. its a deep bore. so really don't see how the push rod can get caught on anything. pedal comes back perfectly. everything works fine.
Old 06-14-2015, 11:33 AM   #3
campingman
Re: Brake Question
anyone know anything about these brakes?
Old 06-14-2015, 01:01 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Brake Question
Let me ask one of the brake engineers just to be sure.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-14-2015, 01:05 PM   #5
campingman
Re: Brake Question
hey man, I really appreciate it! Thanks
Old 06-15-2015, 03:02 AM   #6
andrewmp6
Re: Brake Question
If you can wait for keith i would hes probably talking to the guy who designed that hydro booster.
andrewmp6 is offline   Reply With Quote
Old 06-15-2015, 08:57 AM   #7
Keith Seymore
Re: Brake Question
So - to make sure I understand:
you are missing this spring steel retainer I am pointing to here?
I was imagining more of a snap ring/e clip but when I looked at the drawing of the current part this morning I didn't see a clip in the assembly.
K
1979-1986
1986 - 2019
Old 06-15-2015, 09:35 AM   #8
campingman
Re: Brake Question
yes that is the piece that is missing. the one with the 6 teeth. mine had 4 teeth and 3 broke.
Old 06-15-2015, 09:47 AM   #9
Keith Seymore
Re: Brake Question
PM sent.
K
1979-1986
1986 - 2019
