Transfer case bushings - which way is up?
![]() My task for tomorrow. I'm assuming the thicker bushing on the bottom, but I thought I'd double check. |
Re: Transfer case bushings - which way is up?
I ran the thicker ones on top. Not sure if that's right. It's the way they were when I pulled the old ones out.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I'll dig through the shop manual and see if it says anything. My existing bushings are toast, so I can't tell from what is in there.
I didn't bother with the shop manual, I just dug in and got to work. This was their orientation when I took the originals out:
![]() The thicker bushings (or what was left of the thicker bushings) were on the bottom. Solved that driveline movement problem. Its nice to occasionally have a straightforward solution to a simple problem. Body bushings next. |
1966 Crew Cab & 4X4 Fanatic
I would have put the larger one on the bottom also as this would give it more cushion and handle the weight and torque of the transfer case better than the smaller one. Here is a link.They show it in the description pictures under the cross reference section with the larger one on the bottom. http://www.prothanesuspensionparts.com/71603
if you scroll down that link http://www.prothanesuspensionparts.com/71603 it will give you the opportunity to ask a question. perhaps they can give you the answer
ron |
#7 | |
