Old 06-13-2015, 06:54 PM   #1
ebfabman
So you want patina.....
You want to build an original looking truck with an aged look to it. No expensive paint and body. A trucks finish is only original until someone starts sanding and priming it. Then is gone. Never original again. You're building a custom sleeper with state of the art aftermarket suspension. And maybe an interior that has a few creature comforts and a really cool set of wheels. Its a Chevy so it will naturally have a reliable drive train. You want a medium blue but can only find that blue with the aged look you're after in a long bed and you're building a short wheelbase fleetside truck. The challenge. Cut down the long bed bedsides to short bed bedsides and do it without bondo or primer. Keep as much of the original finish as possible. Maybe just a dusting of color over the welded joints so its not eye grabbing obvious. Let's see what we can do.
ebfabman is offline   Reply With Quote
Old 06-13-2015, 06:58 PM   #2
ebfabman
Re: So you want patina.....
These are for veteran truck builder ATP so it should turn out nice. Can't wait to see what he has up his sleeve on this build!
Old 06-13-2015, 07:41 PM   #3
Dirt's72
Now thats talent. Very nice!
Dirt's72 is offline   Reply With Quote
Old 06-13-2015, 07:58 PM   #4
68bowtie
68bowtie's Avatar
that's amazing
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 06-13-2015, 08:17 PM   #5
65standard
65standard's Avatar
That came out great. Very nice work.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 06-13-2015, 08:37 PM   #6
jessemthompson
That came out really nice. Great job
jessemthompson is offline   Reply With Quote
Old 06-13-2015, 08:47 PM   #7
sourkraut
sourkraut's Avatar
looks good
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 06-13-2015, 09:16 PM   #8
D-rock1981
D-rock1981's Avatar
Nice work
D-rock1981 is offline   Reply With Quote
Old 06-13-2015, 10:27 PM   #9
tommys72
tommys72's Avatar
Looks real good
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 06-13-2015, 10:54 PM   #10
Boog
laying low
Boog's Avatar
That's some fine cuttin and stichin right there. I am enjoying seeing what methods all you guys come up with for shortening these bedsides. Talent and patience. I love it. Thanks for sharing.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-13-2015, 10:56 PM   #11
3drburb
That is freaking awesome! I thought it was trickery at first, until I looked really good.
3drburb is offline   Reply With Quote
Old 06-13-2015, 10:57 PM   #12
swamp rat
swamp rat's Avatar
Your using ESAB Easygrind .023 correct? could you please tell me the heat and feed setting your using and the diameter of the individual spot welds please. Send a PM if you wish, Thanks.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-13-2015, 11:02 PM   #13
rustylew
Can you give us a peek at how you did the front!!!
rustylew is offline   Reply With Quote
Old 06-13-2015, 11:39 PM   #14
ebfabman
Yes easygrind .023 I like to bounce around on the heat. Fast wire feed because its thin wire and soft. I like to hit each weld hot and fast so penetration will be good and keep the haz to a minimum. As far as diameter, 1/8th ish. These pics may help.
Old 06-13-2015, 11:40 PM   #15
ebfabman
Those are mig welds on some nasty scrap.
Old 06-13-2015, 11:48 PM   #16
swamp rat
swamp rat's Avatar
But on the body work you are using spot welds right, the picks look like your laying a regular weld. Thanks for the reply.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-13-2015, 11:54 PM   #17
ebfabman
Both the same, just a little slower on the bedside to help control the heat.
Old 06-14-2015, 12:01 AM   #18
ebfabman
I'll show the front Monday. That's the easy part. It's just 12 inches from the leading edge. I need to get some color that is closer because the blues I have in the shop need a bit of green in them. When the color is closer and its out in the weather a while, should start to look real good.
Old 06-14-2015, 12:23 AM   #19
lolife99
67-72 parts collector,…
lolife99's Avatar
ebfabman,... have you seen this thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=667694
Totally different approach to shortening a 67-72 bed.
I'm sure you could pull this method off also, with your welding skills.
Keith
Convert to disc brakes.
Old 06-14-2015, 12:50 AM   #20
ebfabman
That came out nice. I like how he did the marker lamps and the sheetmetal work is very nice. I like to cut the frames in front of the crossmember but that's me. Good job.
