Tranny question.
My 72 c10 2wd has a turbo 400 tranny in it.Could this be OEM? The sticker in the glove box does not specify.It is a Cheyenne with a factory 402 engine.The reason I am asking is I wanted to change the driveshaft center support bearing but the mounting holes are off a little.I have never changed one of these bearings so maybe I have it on backwards? But it appeared the holes in the old one were off a little also.
Re: Tranny question.
The bearing I bought from Napa had what appeared to be a spacer ring that came with it approx.3/16 wide I put it on the shaft first then the bearing that put the holes an inch or more off so that was 20 bucks down the drain.
The TH 400 came on that truck.
