06-14-2015, 05:05 PM | #1 |
Radeo saround dimentions
Can anyone give me the dimensions of the flat part of the indented area where the radio goes, on a 60-63 c10 dash. I want to cut holes for ac vents but don't know what size to order and I can't get to my truck right now.
06-14-2015, 08:40 PM | #2 |
1961 crewcab
Re: Radeo saround dimentions
2 X 12 at the inside bevel
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-15-2015, 12:12 PM | #3 |
thanks
06-15-2015, 01:06 PM | #4 |
Not sure if this helps...
Looks like 11 1/2 by 2....
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
06-15-2015, 01:06 PM | #5 |
LOL I see that Jonzcustomshop beat me to it!
06-15-2015, 01:09 PM | #6 |
ForestB - Where did you get that little filler piece where that rotary switch is? Im looking for something to fill the hole so I can take my heater controls out.
06-15-2015, 02:04 PM | #7 |
Id use an ashtray front cover. Just remove the assembly and its held on by 2 screws. Then just have to close up the two screws for the ashtray handle.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-15-2015, 02:36 PM | #8 |
Cool. Thanks!
06-15-2015, 06:42 PM | #9 |
I think it is the stock location and panel for that knob.
06-15-2015, 08:57 PM | #10 |
What know is that? blower motor?
06-16-2015, 02:03 AM | #11 |
1961 crewcab
yep
pretty sure that is for the "cheap" heater, after that would be the one with the 2 levers, and then the deluxe with the 4 levers. I have seen a couple with that one knob set up, but up here the 4 lever deluxe was pretty much the norm.
