06-14-2015, 09:33 PM | #1 |
I'm trying....
69-72 Spare tire hardware clarification
As best I can tell the 69-72 Blazers only had a conventional lock nut holding the spare tire disk...and maybe 73 up had the lever-style nut. The lock nut is what's detailed in the assembly manual. Am I missing something? Which one of the below pics is right? Anyone have the lever on a known original truck? Any insight appreciated.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
06-14-2015, 09:35 PM | #2 |
I'm trying....
Re: 69-72 Spare tire hardware clarification
Here are pics of an oft referenced original 72 that shows all the pieces noted in the assembly manual...no lever.
06-15-2015, 05:05 PM | #3 |
good to see. I have a bunch of parts but don't know what goes where.
really clean 72! http://67-72chevytrucks.com/vboard/showthread.php?t=531183[/url] also 1972 2wd blaze. |
06-15-2015, 07:58 PM | #4 |
Carpe manana
Pic by lane224 of the 72 Blazer he's parted, which by report was original and fairly complete, shows a lug nut to affix the spare on the bolt. I suspect this is the correct set-up rather than the lever-action nut but I did not confirm with him whether or not the nut was still attached to the bolt or added when he parted the truck. We need more owners of survivor K5's to chime in...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-16-2015, 09:43 AM | #5 |
I'm trying....
Lug Nut!!! Of course it's a lug nut. That makes too much sense. Thanks for the pic.
06-16-2015, 02:05 PM | #6 |
A little off topic but does anyone have any pictures of how the wheel sits on the mount. Does it rest on top or to the side of it?
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
06-16-2015, 02:26 PM | #7 |
I'm trying....
Don't know if this helps answer what you're asking about, but it's the only other view I had on the computer. If you mean relative to the back of the mount, I can take another shot when I get home.
06-16-2015, 02:29 PM | #8 |
wonder what the biggest tire will fit. 32 11.50?
06-16-2015, 04:47 PM | #9 |
Relative to the back of the mount. If you can grab a picture looking at it from in front of the passenger seat that would be great.
06-16-2015, 05:56 PM | #10 |
I'm trying....
...it rests on the tire at the top. It's super close, but doesn't touch the rim...(on mine anyway).
06-16-2015, 08:19 PM | #11 |
That is exactly what I was looking for. Thanks for grabbing a picture.
06-16-2015, 09:49 PM | #12 |
Emailed you larger pictures but still haven't figured the book out so if someone knows how to read it let me in on the secret. If you look at 70-72 blazer part number 3991023 that is the bolt I have in the picture but is under the heading Plate-Bar-Brace Assy-Bracket, Wheel and Tire
If you look under Nut-Retainer-Washer, Wheel Carrier the 55-70 All, Blazer the bolt is 358501 A.R. I don't know what A.R. stands for but the both look like 7/16 x 20 |
06-16-2015, 09:50 PM | #13 |
LOL forgot to attach pictures
06-16-2015, 10:01 PM | #14 |
I'm trying....
Dwayne....that's awesome. Thanks for the pics. I gotta get one of those books! What about the 1/2-20 lock nut listed a little lower that says 67-70 10 thru 20 and Blazer? Could you look up the lug nut part numbers? I'm just curious if it's the same as the first nut you referenced...if they indeed did put lug nuts on this bolt.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 06-16-2015 at 10:31 PM. |
06-16-2015, 10:39 PM | #15 |
Made a mistake what I thought was Plate-Bar-Brace Assy-Bracket, Wheel and Tire was actually BOLT, Wheel Carrier if you look at the picture again. Also found out what A.R. means "as required." Sent you an email with larger pictures.
06-16-2015, 10:44 PM | #16 |
I'm trying....
Dwayne, what I gather from this is:
1)It was a lock nut and not a lug nut, though it makes sense to me that they would have used the lug nut. 2)You are clearly beach ready. ....thanks for taking time to post those catalogue pics. They are packed with info.
06-16-2015, 10:52 PM | #17 |
Heading back to the beach tomorrow and coming home Monday but I just figured out what you were trying to do and I think you are correct. If you look at the very first picture I posted it reads 55-70 358501 if you look at the 3rd picture on the second set of pictures 69-72 blazers is 358501 so I think up to 70 they used a lug nut. Let me know what you think!!
06-16-2015, 10:57 PM | #18 |
I'm trying....
Well upon further review, I think I stand corrected. Looks like the green oval indeed shows a part # crossover between the lug nuts and wheel carrier....but it's getting late and I'm toast. Thanks again Dwayne.
06-16-2015, 10:58 PM | #19 | |
I'm trying....
06-17-2015, 01:24 AM | #20 |
Now I need to dig my spare tire carrier out of my parts bin and check the hardware. Still looking for the 4 bolts to mount to the floor. Anybody have OEMs or know what size the bolts are?
06-17-2015, 07:27 AM | #21 |
This is it l believe.
same thread as seat belt. |
06-17-2015, 07:37 AM | #22 |
Another pic 3rd and 4th bolts from the left.
06-17-2015, 10:56 AM | #23 |
06-17-2015, 08:14 PM | #24 |
Aprox 1 3/4 long. Same thread as seat belt bolt.
06-19-2015, 07:02 AM | #25 |
Carpe manana
For the record: spare tire pic from a 78 Blazer shows the lever action nut
