Due to time, I had someone else strip my chassis. So I'm not sure which way these things came off.
The pic below shows the 2 rubber squeak pads that were between edge of the fuel tank and the bracket that sandwiches between the tank and the frame. Why are they long and triangular at the one end? Which way does that face, forward or rearward? The assembly manual doesn't really show them that well. Thanks for any help.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Re: Fuel tank anti squeak rubber help
that looks like a piece of innertube that someone cut up. The replacement tank kit I got came with some anti squeak felts that look like roofing felt that I just laid across the fuel tank lip and pinched it between the tank and the frame.
I'm not sure if I did it right by not running the bolts through the holes on the tank, but the way I did it is how they were ran when I took the old tank off, and it's been staying put *knocks on wood*.
My toys: 1971 GMC Jimmy 2008 Hummer H3 Adventure 2003 HD Road King |
Mine tank was replace by the PO and the anti squeak pads were reused. They look exactly like the ones you show. This photo somewhat shows how they fit.
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
#4 | |
I appreciate the picture. Looks like at least on that passenger side photo it goes towards the front.
Member Seventyone lent me his originals to make mock ups using a Neoprene Sheet, 60A Durometer that I bought on Amazon for 20 bucks. It's .125" thick and 6" wide and 36" length that you can cut to form the same shape as your originals. I have them installed but I can't confirm they actually keeping them from squeaking.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#6 | |
Yep, just like the ones you have there. I'll have to double check and see which way I have them pointed.
I have mine pointed to rear. There wasn't any particular reason why I did it this way so cant say for sure if it's correct. My tank is completely bolted down and the front (where the rest of the edge of the tank is exposed) has about a 1/4' space between the frame rail. Hope that helps
Here are what I found to be the original GM rubber
http://www.ebay.com/itm/111649326447...%3AMEBIDX%3AIT
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
#10 | ||
