Has anyone used this to with an LM7 into a 66?
Morning all,
Looks like I have sold the SBC that Woody came with so can now start to execute on the plan to install a LM7. Question I have is... Has anyone used this kit from Pace - http://paceperformance.com/i-5146180...rsion-kit.html Look to have all the salient parts minus the clutch arm. My question is, should I go with the manual set up or go to a hydraulic? Either thrust bearing or slave cylinder? Not 100% sure if my budget will stretch to an TKO600 at this time so might well use an M22 I have whilst I save up more pennies. So bear in mind that the transmission is still fluid when answering. Hopefully the same set up will work for both. Look forward to your comments and pointers. Regards, P. ![]() |
