Old 06-15-2015, 01:43 PM   #1
MARKDTN
'83 K20 Tire Pressure Recommendation
I have an '83 K20 with stock wheels. I am looking for the recommended tire pressure. I thought it would be easy to find, but it's not. I do not have a door sticker and from what I can see it would be for the original 215/85/16s anyway. I am running 245/75/16 Bridgestone Revo ATs. I have had this truck since '91 and have always run this tire combo, but as I get older I am getting more cautious about tire pressure. I have not really driven it in about a year, and this morning they were all around 40 psi. In the past, I have been putting them around 60 psi, but looking for some validation. Anybody have any thoughts on this?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-15-2015, 07:12 PM   #2
donut
donut's Avatar
Re: '83 K20 Tire Pressure Recommendation
What does the sidewall of the tire say?
When I owned the K-20, tire pressures would depend on load. Winter with the plow 60psi.
Summer driving 40-45 psi, whatever was comfortable. Keep and eye on the wear pattern of the tires, they can tell you what they like.
Edit-- the tires were rated for those pressures.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 06-15-2015, 09:54 PM   #3
rich weyand
rich weyand's Avatar
I think those pressures are high. Draw a chalk line across the tread of the tire, then drive about a hundred feet and look at them The chalk line will wear evenly across the tread if the pressure is right. If the chalk line is gone in the center and still there on the outside, the pressure is too high; if the chalk line is gone on the sides and still there in the center, the pressure is too low.
BTW, the tire pressure times the area of the contact patch has to hold up the vehicle. If you underinflate, the tires will flatten until the contact patch times the pressure equals the load, and if you overinflate, the tire will stand up on the center of the tread until the contact patch times the pressure equals the load. So the pressures should go up if you are carrying a load, and down if you are running fatter tires with more tread width.
On my 78 K10, I run 35 in the front and 30 in the back unloaded on BFG 31x10.5R15, because the fronts have more load on them than the backs. I run 35 all around when I am loaded in the back.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 06-16-2015, 07:57 AM   #4
MARKDTN
Sidewall says 80 max, but I have found out that this is not what you should inflate to.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 06-16-2015, 12:02 PM   #5
Liberty
Liberty's Avatar
What does your Driver door say?
Liberty is offline   Reply With Quote
Old 06-16-2015, 12:03 PM   #6
gramps77
Sir,
He stated he DOES NOT have the sticker there.
gramps77 is offline   Reply With Quote
Old 06-16-2015, 12:27 PM   #7
Bigstevex4
Bigstevex4's Avatar
The door sticker is the correct way some one should have one but there going to have them as if loaded. 40 is about right 35 rear un loaded
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 06-16-2015, 12:49 PM   #8
Liberty
Liberty's Avatar
Originally Posted by gramps77 View Post
Sir,
D'oh! That's what I get for not reading it close enough.
Old 06-16-2015, 01:15 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
My ck2500 is at 40 up front and 30 psi out back. Unless it's actually working...
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-16-2015, 01:28 PM   #10
rich weyand
Tire inflations and load limits are covered in section 3E of the Light Truck Service manual.
The 1983 manual only covers P215 and P235 tires, for which the load limit at 36 psi is 1532 and 1742 pounds per tire respectively.
Note how the load limit goes up as the tread width increases, because there is more tire patch. For a 245 tire at 36 psi, the load limit should be around 1847 pounds per tire.
At 44 psi, P215 and P235 tires have a load limit of 1742 and 1984 pounds respectively. P245 should be around 2105 pounds per tire.
You can scale these pressures, such as the load limit for 40 psi should be halfway between the load limit for 36 and 44.
You should be able to get your weight per axle pretty easy at some local outfit with a scale, like a grain elevator.
Rich Weyand
1978 K10 RCSB DD.
Old 06-16-2015, 05:32 PM   #11
1976gmc20
I've always run about 50-55 in mine, but then I haul loads sometimes, and run a lot on gravel roads.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-16-2015, 07:35 PM   #12
tucsonjwt
I have an 83 C20 with 235/85R16 tires. I am attaching the stickers on my door. I drive at slow speeds around town and keep them at 44 lbs. front and rear. If hauling a heavy load, I inflate to 60 lbs. My tires are well worn, and if I inflate them to 60 lbs. with no load, and then stop abruptly, the rear wheels will lock up. Ride is much better at 40 lbs. and the tires seem to wear evenly.
tucsonjwt is offline   Reply With Quote
Old 06-16-2015, 07:40 PM   #13
imjeff
imjeff's Avatar
As was mentioned earlier, chalk them. Then if you have a load on you can air up the rears.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
